楼主: qiyi0507
RT809F连接不上创维39E580F 8A08机芯
 楼主| 发表于: 2015-11-30 12:23:27
这是打印信息, 会英文的可以帮我翻译,判断一下吗?
2015-11-29, 16:15:47
COM6, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4, Printed by RT809F:
0x0005e0ef
0x011100ff
Aug 24 201209:04:16PHY trainning Result=0x00000000
Training result:
        RSLR0=00000249
        RDGR0=00000096
        DLLCR0=00000000
        DLLCR1=00000000
        DLLCR2=00000000
        DLLCR3=00000000
        DQTR0=ffffffff
        DQTR1=ffffffff
        DQTR2=ffffffff
        DQTR3=ffffffff
        DQSTR=000006db
        DQSNTR=000006db
Stage 00 Result 00000000
Stage 01 Result 00000000
Stage 02 Result 00000000
M2C Systemp Started
Embedding cold heart...
__TEXT_BASE: 0x8f800000
0xea000012
0xe59ff014
0xe59ff014
0xe59ff014
0xe59ff014
0xe59ff014
0xe59ff014
0xe59ff014
0x8f000100
0x8f000160
0x8f0001c0
0x8f000220
0x8f000280
0x8f0002e0
0x8f000340
0x12345678
ucl decompress
ready
懆H(T戟        S覀?偮z挗z拏姃B
U潄挗拏姃j偸覀⒁倸JjぴH垟U↗獖?j?5R﨨AND:  Amlogic nand flash uboot driver for m2, Version 1.0 (c) 2010 Amlogic Inc.
No NAND device found!!!
NAND device id: 0 0 0 0 0 0
nand init faile: -6
nand init faile: -6
MMC:   SDIO Port A: 0
emmc read env ok
In:    serial
Out:   serial
Err:   serial
KGDB:
ready
suspend = off
cold_heart_status = 0xed948026
Net:   select eth clk-0,source=400000000,out=50000000
Apollo EMAC
Dcache status 1
Icache status 1
******WTD enabled in switch_boot_mode******
emmc save env ok
---data value = AIO-09:04/08/24/2012----
reboot_mode_current=4e63b256
AMLOGIC_CHARGING_REBOOT...
Hit any key to stop autoboot:  1  0
******WTD enabled for normal boot******
Booting from mmc ...
Device: SDIO Port A
Manufacturer ID: 0
OEM: 0
Name: 圱ran Speed: 40000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 3046113280
Bus Width: 1-bit
Partition Map for UNKNOWN device 0  --   Partition Type: DOS
Partition     Start Sector     Num Sectors     Type
    1                     16065           7711200         b
Device: SDIO Port A
Manufacturer ID: 0
OEM: 0
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Bus Width: 1-bit
    1                     16065           7711200         b
MMC read: dev # 0, addr # 1800000, byte count 480000 ... 9216 blocks read: OK
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-2.6.34
   Image Type:   ARM Linux Kernel Image (lzma compressed)
   Data Size:    3354113 Bytes = 3.2 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Using machid 0xb8e from environment
Starting kernel ...
发表于: 2015-11-30 13:09:25
什么故障,先升级主程序试试
 楼主| 发表于: 2015-11-30 14:44:32
wuyuefeng2011 发表于 2015-11-30 13:09
什么故障,先升级主程序试试
现在求升级程序
GMT+8, 2026-9-18 19:30 , Processed in 0.049241 sec., 9 queries .
