楼主: zero2048
RT809H - NAND bad blocks
发表于: 2017-6-11 23:10:24
get a software that format  nand flash  and then write  again  i hope your problem may be solve..
发表于: 2017-9-22 17:03:32
Hello Any solution to this problem?
发表于: 2018-3-8 21:09:53
zero2048 发表于 2017-2-11 03:02
I used AUTO mode at first then I tried manual - no luck. I hope that the developers will correct thi ...
一开始我用的是自动模式,后来我试了手动模式-真倒霉。我希望开发商能尽快纠正这个问题。
而且也不可能用更大的字体写。例如,您有2个gb文件,并且正在尝试将其写入4gbnand中——程序员在50%的时候会陷入停滞,然后数小时内什么都不会发生。
软件人,请让我们的梦想成真。拜托!
如果你能,请联系管理员-很遗憾我不会说中文。
发表于: 2018-3-8 21:16:29
人家说的很清楚啊就是编程器不能避开有坏块的地方写入造成烧录不成功
发表于: 2018-6-21 16:06:33
l 在再在再在再在
发表于: 2018-6-25 07:31:01
i have exactly the same problem with NAND K9GAG08U0ESCB0@TSOP48, the RT809H just cannot deal with bad blocks in nand chips.. its also very with bad with verification of large nand chips.
i purchased some of these programmers for our UK Store but now seeing this problem will have to look for different programmers that can work with large nand chips.
FletchUK
GMT+8, 2026-10-18 14:12 , Processed in 0.058893 sec., 10 queries .
