查看: 4774|回复: 6
TCL.LCD.MS801机芯三无灯亮
发表于: 2016-4-6 08:21:44
故障编码:
112
故障现象:
三无(灯亮)
机芯:
LCD MS801机芯
机型:
L46V7300A-3D,L46V7500A-3D,L55V7500A-3D,L65V7500A-3D,L39E5050A-3D,L43E5060A-3D,L48E5060A-3D,L50E5050A-3D,L39F3390A-3D,L48F3390A-3D,L55F3390A-3D,L58X9200A-3D,L32E5300A,L32E5300D,L37E5300D,L40E5300A,L42E5300A,L42E5300D,L46E5300A,L32E4500A-3D,L37E4500A-3D,L42E4500A-3D,L50E4500A-3D,L46E5300D,L47V6500A-3D,L55V6500A-3D,L46E5300D-3D,L42V6500A-3D,L37E5300A,L43F3390A-3D,L39E4380A-3D,L42E4380A-3D,L50E4380A-3D,L65E4380A-3D,L65V7590A-3D,L32E4380A-3D,L37E4550A-3D,L37E4560A-3D,L42F1580A-3D,L32E4550A-3D,L43V7300A-3D,L55V7300A-3D,L32E5500A-3D,L42E5500A-3D,L46E5500A-3D,L50E5500A-3D,L55E5500A-3D,L43E5310A-3D,L48E5310A-3D,L32F3500A-3D,L37F3500A-3D,L39F3500A-3D,L40F3500A-3D,L42F3500A-3D,L46F3500A-3D,L48F3500A-3D,L55F3500A-3D,LE55M99AD,L65E5500A-3D,L39E4600A-3D,L42E4600A-3D,L48E4600A-3D,L40E5590A-3D,L46E5590A-3D,L55E5590A-3D,L39E4650AN-3D,L42E4650AN-3D,L48E4650AN-3D,L39E4660AN-3D,L42E4660AN-3D,L48E4660AN-3D,L39E4680AN-3D,L42E4680AN-3D,L48E4680AN-3D,L65F3500A-3D,L46E5610A-3D,L55E5610A-3D,L55E5390A-3D,L32F3570A-3D,L42F3570A-3D,L46F3570A-3D,L43E5390A-3D,L42E5610A-3D,L32E5390A-3D,L46F3510A-3D,L32F3510A-3D,L42F3510A-3D,L39E4610A-3D,L48E4610A-3D,L48E5390A-3D,L32E5500J-3D,L32F3500J-3D,L42E4610A-3D,L28D66A-M,L28D66A-P,L28D66A-W,L32F6620B
检修过程:
通电灯亮,不能二次开机,测量电源板输出的电压均正常,说明故障在数字板,测量数字板板各个供电,12V电路正常,然后测量3.3V,2.5V,1.5V均没有,这些电压都是5V提供的,测量5V没有,说明故障在24V-5V的DC-DC电路。测量5V没有对地短路,测量Q004的5-6脚24V正常,U004的7脚12V也正常。于是逐个更换Q004 A04832和U005 RT8110B,故障依旧。测量周围的取样电阻和一些电容,没有发现异常,维修陷入困境。仔细测量5V的输出电路,开机瞬间5V有2V,然后慢慢降到0V,难道是保护了?RT8110B的第6脚是过流保护监测脚,此脚外接一个电容C039到第5脚,起到保护作用,于是更换此电容,故障排除。(TCL多媒体技术群 李亮亮提供)
故障板名称:
数字板
故障元件位号:
C039
处理措施:
更换C039
图片:
发表于: 2017-1-22 21:44:41
谢谢了看看了
发表于: 2017-5-12 08:14:17
谢谢好经验分享,图文并茂,说的详细。
发表于: 2017-5-12 08:27:53
看看了,好经典
发表于: 2017-5-30 06:45:56
谢谢好经验分享,正在需要
发表于: 2017-5-31 16:23:07
谢谢,刚好用上
GMT+8, 2026-11-4 02:22 , Processed in 0.056297 sec., 12 queries .
