查看: 587|回复: 1
师傅帮我看这个安卓板开机打印信息是怎么了,不显示
发表于: 2025-6-8 09:29:07
DDR Version 1.04 20140217
In
DDR3
300MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Memory OK
OUT
BUILD=====2
No.1 FLASH ID:ad de 94 eb 74 44
ReadRetry pageadd=20987f  ecc=28 err=ffffffff
Read pageadd=20987f  ecc=28 err=ffffffff
spare: 0x0:826f0c2 9ca3 e0e0faf5 e0e0e0e0
ReadRetry pageadd=209843  ecc=28 err=ffffffff
Read pageadd=209843  ecc=28 err=ffffffff
spare: 0x0:b8995343 b0bf3f22 505fa3c2 505f4361
ReadRetry pageadd=20987c  ecc=28 err=ffffffff
Read pageadd=20987c  ecc=28 err=ffffffff
spare: 0x0:826f0c2 9ca3 e0e00043 e0e0e0e0
ReadRetry pageadd=20a411  ecc=28 err=ffffffff
Read pageadd=20a411  ecc=28 err=ffffffff
spare: 0x0:1b0b798c 1b02416c 1b82590d 1b82190c
OK! 740185
unsigned!
SecureBootEn = 0 0
Boot ver: 2014-07-22#2.16
start_linux=====750926
1364482 Starting kernel...@0x60408000
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.0.36+ (qidong@ubunt-PowerEdge-T420) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1743 SMP PREEMPT Sat May 21 10:58:27 CST 2016
[    0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: RK30board
[    0.000000] memory reserve: Memory(base:0x91800000 size:80M) reserved for <ion>
[    0.000000] memory reserve: Memory(base:0x90000000 size:24M) reserved for <fb0 buf>
[    0.000000] memory reserve: Memory(base:0x8fa00000 size:6M) reserved for <camera_ipp_mem>
[    0.000000] memory reserve: Total reserved 110M
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] bootconsole [earlycon0] enabled
[    0.000000] CPU SRAM: copied sram code from c0b38000 to fef00100 - fef020c8
[    0.000000] CPU SRAM: copied sram data from c0b39fc8 to fef020c8 - fef02844
[    0.000000] sram_log:   @      0q   @       P    1      /  !    aB@ 2   `" 2q    : 4q
[    0.000000] CLKDATA_MSG: pll_flag = 0x03
[    0.000000] cpll auto set rate error
[    0.000000] CLKDATA_ERR:     can't get a available nume and deno
[    0.000000] CLKDATA_ERR:     clk_frac_div can't get rate=48000000,uart0_frac_div
[    0.000000] L310 cache controller enabled
[    0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
[    0.000000] DDR DEBUG: version 1.00 20131106
[    0.000000] DDR DEBUG: DDR3 Device
[    0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[    0.000000] DDR DEBUG: init success!!! freq=300MHz
[    0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=0 extra clock, DGPS=360
[    0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[    0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
[    0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[    0.000000] PERCPU: Embedded 7 pages/cpu @c1dec000 s6976 r8192 d13504 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 231936
[    0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00130000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00200000@0x00080000(userdata),0x00002000@0x00280000(kpanic),0x00100000@0x00282000(system),-@0x00382000(user) bootver=2014-07-22#2.16 firmware_ver=4.1.1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 762MB 152MB = 914MB total
[    0.000000] Memory: 907256k/907256k available, 141320k reserved, 155648K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xff600000 - 0xffe00000   (   8 MB)
[    0.000000]     vmalloc : 0xf7000000 - 0xfe800000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf6800000   ( 872 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .init : 0xc0408000 - 0xc0433000   ( 172 kB)
[    0.000000]       .text : 0xc0433000 - 0xc0ac1d24   (6716 kB)
[    0.000000]       .data : 0xc0ac2000 - 0xc0b37068   ( 469 kB)
[    0.000000]        .bss : 0xc0b3b024 - 0xc15e3178   (10913 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:352
[    0.000000] rk30_gpio_init: 128 gpio irqs in 4 banks
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] rk_timer: version 1.2
[    0.003721] Calibrating delay loop (skipped) preset value.. 1631.46 BogoMIPS (lpj=8157341)
[    0.012811] pid_max: default: 32768 minimum: 301
[    0.018095] Mount-cache hash table entries: 512
[    0.023619] Initializing cgroup subsys debug
[    0.028356] Initializing cgroup subsys cpuacct
[    0.033303] Initializing cgroup subsys freezer
[    0.038252] CPU: Testing write buffer coherency: ok
[    0.124497] CPU1: Booted secondary processor
[    0.164488] CPU2: Booted secondary processor
[    0.204485] CPU3: Booted secondary processor
[    0.204514] Brought up 4 CPUs
[    0.222012] SMP: Total of 4 processors activated (6525.87 BogoMIPS).
[    0.229325] devtmpfs: initialized
[    0.238866] NET: Registered protocol family 16
[    0.243890] last_log: 0xef500000 map to 0xf7004000 and copy to 0xc0b3f180 (version 2.1)
[    0.267701] lcdc0 is used as primary display device contoller!
[    0.274242] warning:lcdc1 not add to system!
[    0.379235] rk29sdk_wifi_bt_gpio_control_init: init finished
<hit enter to activate fiq debugger>
[    0.386855] console [ttyFIQ0] enabled, bootconsole disabled
[    0.395990] Registered FIQ tty driver ef435cc0
[    0.396536] Loaded driver for PL330 DMAC-1 rk29-pl330
[    0.396579]  DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.396762] Loaded driver for PL330 DMAC-2 rk29-pl330
[    0.396802]  DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
[    0.428672] bio: create slab <bio-0> at 0
[    0.433069] SCSI subsystem initialized
[    0.433279] usbcore: registered new interface driver usbfs
[    0.433390] usbcore: registered new interface driver hub
[    0.447641] usbcore: registered new device driver usb
[    0.447907] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
[    0.448159] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
[    0.448351] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
[    0.448529] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
[    0.448718] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
[    0.479231] rk30-adc rk30-adc: rk30 adc: driver initialized
[    0.479509] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.479940] Bluetooth: Core ver 2.16
[    0.480007] NET: Registered protocol family 31
[    0.480043] Bluetooth: HCI device and connection manager initialized
[    0.480093] Bluetooth: HCI socket layer initialized
[    0.480131] Bluetooth: L2CAP socket layer initialized
[    0.480181] Bluetooth: SCO socket layer initialized
[    0.481217] rk fb probe ok!
[    0.486094] act8846_set_init,line=17
[    0.486126] act8846_set_init:g_pmic_type=3
[    0.487914] act8846_set_init  act_dcdc1 =1200000mV end
[    0.489795] act8846_set_init  vdd_core =1000000mV end
[    0.491671] act8846_set_init  vdd_cpu =1000000mV end
[    0.493547] act8846_set_init  act_dcdc4 =3000000mV end
[    0.494794] act8846_set_init  act_ldo1 =1000000mV end
[    0.495937] act8846_set_init  act_ldo2 =1200000mV end
[    0.497076] act8846_set_init  act_ldo3 =1800000mV end
[    0.498217] act8846_set_init  act_ldo4 =3300000mV end
[    0.499359] act8846_set_init  act_ldo5 =3300000mV end
[    0.500500] act8846_set_init  act_ldo6 =3300000mV end
[    0.501641] act8846_set_init  act_ldo7 =1800000mV end
[    0.502782] act8846_set_init  act_ldo8 =2800000mV end
[    0.502826] act8846_set_init,line=79 END
[    0.502892] i2c-core: driver [act8846] using legacy suspend method
[    0.502938] i2c-core: driver [act8846] using legacy resume method
[    0.503104] Switching to clocksource rk_timer
[    0.503835] Switched to NOHz mode on CPU #0
[    0.504524] Switched to NOHz mode on CPU #2
[    0.504538] Switched to NOHz mode on CPU #1
[    0.504550] Switched to NOHz mode on CPU #3
[    0.509932] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xf70b0000
[    0.510011] --luoxt-- lcd_param 0
[    0.510038] --luoxt-- lcd_param 0
[    0.510064] --luoxt-- lcd_param 0
[    0.510089] --luoxt-- lcd_param 0
[    0.510115] --luoxt-- lcd_param 0
[    0.510141] --luoxt-- lcd_param 0
[    0.510166] --luoxt-- lcd_param 0
[    0.510191] --luoxt-- lcd_param 0
[    0.510216] --luoxt-- lcd_param 0
[    0.510242] --luoxt-- lcd_param 0
[    0.510268] --luoxt-- lcd_param 0
[    0.510293] --luoxt-- lcd_param 0
[    0.510318] --luoxt-- lcd_param 0
[    0.510344] --luoxt-- lcd_param 0
[    0.510369] --luoxt-- lcd_param 0
[    0.510394] --luoxt-- lcd_param 0
[    0.510420] --luoxt-- lcd_param 0
[    0.510446] --luoxt-- lcd_param 0
[    0.510471] --luoxt-- lcd_param 0
[    0.510496] --luoxt-- lcd_param 0
[    0.510522] --luoxt-- lcd_param 0
[    0.510547] --luoxt-- lcd_param 0
[    0.510572] --luoxt-- lcd_param 0
[    0.510598] --luoxt-- lcd_param 0
[    0.510624] --luoxt-- lcd_param 0
[    0.510649] --luoxt-- lcd_param 0
[    0.510675] screen->x_res=0 screen->y_res=0
[    0.510710] -luoxt- line 375  type 1 OUT_FACE 0 LVDS_FORMAT 0
[    0.510760] -luoxt- line 377 screen info :
[    0.510768]  H_VD :1280
[    0.510773]  V_VD :800
[    0.510777]  LCD_WIDTH :216
[    0.510782]  LCD_HEIGHT: 135
[    0.510788]  LCDC_ACLK :500000000
[    0.510794]  DLCK: 71000000
[    0.510799]  H_BP: 210
[    0.510804]  H_FP: 16
[    0.510809]  H_PW: 22
[    0.510813]  V_BP: 16
[    0.510818]  V_FP: 34
[    0.510822]  V_PW: 4
[    0.511014] -luoxt- HSYNC_POL: 1, VSYNC_POL: 1, DEN_POL: 0, DCLK_POL: 0
[    0.511072] fb0:win0
[    0.511077] fb1:win1
[    0.511081] fb2:win2
[    0.511172] rk3188 lcdc0 clk enable...
[    0.536282] rk3188 lcdc0 clk disable...
[    0.595961] fb0:phy:90000000>>vir:f8000000>>len:0x1800000
[    0.596242] rk_fb_register>>>>>fb0
[    0.596537] rk_fb_register>>>>>fb1
[    0.596587] rk3188 lcdc0 clk enable...
[    0.596630] lcdc0: dclk:66000000>>fps:51
[    0.596665] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
[    0.596712] lcdc0 wakeup from standby!
[    0.596743] lcdc0 win0 open,atv layer:1
[    0.597177] rk3188 lcdc0 probe ok!
[    0.598252] NET: Registered protocol family 2
[    0.598400] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.598786] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.600662] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.601757] TCP: Hash tables configured (established 131072 bind 65536)
[    0.601806] TCP reno registered
[    0.601836] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.601905] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.602217] NET: Registered protocol family 1
[    0.602414] RK29 Backlight Driver Initialized.
[    0.602614] Unpacking initramfs...
[    0.613202] rk_fb_io_init===========
[    0.661541] Freeing initrd memory: 1216K
[    0.661644] PMU: registered new PMU device of type 0
[    0.661763] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 6
[    0.661818] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 6
[    0.662950] rk3188 cpufreq version 2.1, suspend freq 816 MHz
[    0.663945] highmem bounce pool size: 64 pages
[    0.664121] ashmem: initialized
[    0.668804] fuse init (API version 7.16)
[    0.669916] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.669976] io scheduler noop registered
[    0.670007] io scheduler deadline registered
[    0.670082] io scheduler cfq registered (default)
[    0.677294] rga: Driver loaded succesfully
[    0.677486] rk_serial.c v1.6 2013-12-23
[    0.677590] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
[    0.677760] rk_serial rk_serial.0: membase 0xf70b8000
[    0.677801] out serial_rk_probe serial--0
[    0.677868] rk_serial.1: ttyS1 at MMIO 0x10126000 (irq = 67) is a rk29_serial.1
[    0.678023] rk_serial rk_serial.1: membase 0xf70bc000
[    0.678064] out serial_rk_probe serial--1
[    0.678137] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
[    0.678307] rk_serial rk_serial.3: membase 0xf70c0000
[    0.678347] out serial_rk_probe serial--3
[    0.678592] Rockchip ion module(version: 1.0) is successfully loaded
[    0.681094] loop: module loaded
[    1.000399] SW2001 verify success!
[    1.000480] Register sw2001 driver success.
[    1.000523] Android kernel panic handler initialized (bind=kpanic)
[    1.001003] PPP generic driver version 2.4.2
[    1.001161] PPP Deflate Compression module registered
[    1.001195] PPP BSD Compression module registered
[    1.001754] PPP MPPE Compression module registered
[    1.001790] NET: Registered protocol family 24
[    1.001877] usbcore: registered new interface driver asix
[    1.001937] usbcore: registered new interface driver cdc_ether
[    1.001998] usbcore: registered new interface driver dm9620
[    1.002057] usbcore: registered new interface driver SR9700_android
[    1.002118] usbcore: registered new interface driver net1080
[    1.002176] usbcore: registered new interface driver cdc_subset
[    1.002243] usbcore: registered new interface driver zaurus
[    1.002288] cdc_ncm: 04-Aug-2011
[    1.002334] usbcore: registered new interface driver cdc_ncm
[    1.002370] Rockchip WiFi SYS interface (V1.00) ...
[    1.002426] Initializing USB Mass Storage driver...
[    1.002490] usbcore: registered new interface driver usb-storage
[    1.002528] USB Mass Storage support registered.
[    1.002640] usbcore: registered new interface driver usbserial
[    1.002700] USB Serial support registered for generic
[    1.002761] usbcore: registered new interface driver usbserial_generic
[    1.002801] usbserial: USB Serial Driver core
[    1.002850] USB Serial support regi
发表于: 2025-6-8 11:09:53
可你是EMMC 坏了,运行中途就停止了。
GMT+8, 2026-3-21 11:48 , Processed in 0.050434 sec., 10 queries .
