楼主: 砍柴人
【已解决】求康佳 LED32IS97N 程序 谢谢
发表于: 2014-1-9 10:05:17
砍柴人 发表于 2014-1-8 22:22
MST6178
*35014698
35014698这个引导程序我没有,看下打印信息是什么?
 楼主| 发表于: 2014-1-9 22:56:11
UART_115200
BIST0-OK
BIST1-OK
[123456789][0123456789]-54
[12345678][0123456789]-44
_nPD
U-Boot 1.1.6 (Mar 19 2010 - 17:39:59)
Board: MSTAR TITANIA (CPU Speed 504 MHz)
DRAM:  0x8000000
Skipping flash_init
Flash:  0 kB
NAND:  nand_bbt: searching bbt....Bad block table found at page 262080, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 262016, version 0x01
nand_read_bbt: Bad block at 0x14260000
512 MiB
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MSVC00B000100100208768TH0000000
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80   Group1:88    Group2:200   Group3:f1
Change MIU1 select.....
Group0:4200  Group1:e00   Group2:30    Group3:4000
start init IIC-------------->
come to konka path----@1------
EEPROM @0x0 read: addr 80200000  off 1ffa  count 1 ... cmd: md.b 0x80200000 0x1
80200000: a5    .
done
EEPROM @0x0 read: addr 80400000  off 1ffb  count 1 ... cmd: md.b 0x80400000 0x1
80400000: 5a    Z
done
memory display value read from eeprom ----->:80200000: 5a5aa5a5    ..ZZ
80400000: 8000105a    Z...
data_1[1FFA]--->:a5
data_2[1FFB]--->:5a
---------->defatult_set is:165
---------->defatult_set1 is:90
*ucp is:165
*ucp1 is:90
startFlag_2 is:-1
keypad_pressed is [0]
0x00220000-0x1f240000 : "mtd=3"
Volume KL found at volume id 0
read 4194304 bytes from volume 0 to 81000000(buf address)
## Booting image at 81000000 ...
   Image Name:   Linux-2.6.28.10-mstar
   Created:      2010-03-30   2:43:22 UTC
   Image Type:   MIPS Linux Kernel Image (lzo compressed)
   Data Size:    3404549 Bytes =  3.2 MB
   Load Address: 80400000
   Entry Point:  80404150
   Uncompressing Kernel Image ... OK
Starting kernel ...
就到这里!!
发表于: 2014-1-10 12:33:45
Flash:  0 kB
感觉没有读到,要不FLASH坏了。兄弟但那个引导真没有
要不试下这个,取下先备份后刷这个平台一样板号不一样试下
LED32IS95N_引导程序MST6I78_W25Q80_板号35014971_三星_LTA320AP18编码71001350
 楼主| 发表于: 2014-1-10 23:59:38
antyfeng 发表于 2014-1-10 12:33
Flash:  0 kB
谢谢了
 楼主| 发表于: 2014-1-11 00:00:22
这个能用
发表于: 2014-1-17 00:12:07
thank you very much
发表于: 2016-1-28 16:22:00
你这个引导是什么刷的,我也碰到一台一样的机子,红灯亮不开机
发表于: 2016-12-19 23:04:57
谢谢了下载了
GMT+8, 2026-11-7 11:37 , Processed in 0.058804 sec., 9 queries .
