楼主: jinxing630
创维55S1YP(7S68机芯)开机卡LOGO求助
发表于: 2022-11-2 18:54:38
AC_ON
04-2L-DM-01-20180531
MIU0_DQS-OK
BIST0-OK
BIST1-OK
FT....
#_LED3 0%->20%
eMMC_RPMB_Check_Program_Key
*NOTICE:  BL3-1: v1.1(debug):a1acd7d
NOTICE:  BL3-1: Built : 00:57:42, Jun  8 2018
INFO:    warmboot return address : 5c901c00
INFO:    BL3-1: Initializing runtime services
ERROR:   From args : smp boot address not pass from teeloader
INFO:     [Booting] mstar_send_magic_ATF 344
INFO:    BL3-1: Initializing BL3-2
[Ramlog] ramlog_init init success
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x20100aac
INFO:    BL3-1: Next image spsr = 0x1d3
INFO:    BIN1_32bit mode Jun  8 2018 00:57:40
INFO:    R1 0
INFO:    R2 0
INFO:    R3 0
U
Relocation Offset is: 01600000
[AT][MB][start ub][942]
U-Boot 2011.06-00000-g553581b-dirty (Jul 04 2019 - 17:03:54)
[Utopia][SYS]: Function = SYSOpen, Line = 1215, current resource pri_shm content is: 0ia..................
[Utopia][SYS]: Function = SYSOpen, Line = 1234, [SYS INFO] OPEN INSTANCE...
create instance at 277F1870 with private size 128 bytes at 277F18C0
[Utopia][MIU]:
[MIU INFO] miu opencreate instance at 277F1948 with private size 104 bytes at 277F1998
create instance at 277F1A08 with private size 60 bytes at 277F1A58
uboot held at [275DDF60~28900000],size=013220A0
DRAM:  137 MiB
Now running in RAM - U-Boot at: 27E00000
eMMC: HS400 200MHz
eMMC 7.28 GB [E8FFF8h]
发表于: 2022-11-2 18:56:11
何贵君 2022-11-2 18:54
AC_ON
MIU0_DQS-OK
我就再靠近射频端口旁边的HDIM连接的,有打印信息
发表于: 2023-3-12 22:55:51
我是飞线才有的   HDMI 口也都没有出现打印
发表于: 2023-3-13 11:57:55
用全线的高清线,创维的需要一个使能信号,有的线少线,主板的门三极管不工作,
发表于: 2025-11-6 14:35:53
jinxing630 2022-5-17 14:17
这台机器板子,知道串口在哪的师傅指教一下
电视的HDHMI
GMT+8, 2026-11-2 14:33 , Processed in 0.063215 sec., 9 queries .
