查看: 2272|回复: 10
BBK 39LEX-5027/T2C  CV338H-T42 R809H
发表于: 2018-12-10 15:58:19
help connect rt809h
 楼主| 发表于: 2018-12-10 16:00:35
041:  Using Mode-A to scan VGA port...
042:  Mode-A cannot identified the circuit board, change line sequence to Mode-D and continue to identifying...
043:  Mode-D cannot identified the circuit board, change line sequence to Mode-B and continue to identifying...
044:  Mode-B cannot identified the circuit board, change line sequence to Mode-C and continue to identifying...
045:  Scan SPI extension interface...
046:  Boot error, please check whether the EC chip is supplied voltage and ISP cable is connected properly or not. The ISP cable should not exceed 10cm in length.
047:  Chip is not recognized, please check whether the circuit board is powered on and ISP cable is connected properly or not. If all ok, it maybe the chip is damage.
 楼主| 发表于: 2018-12-10 16:02:31
KLM4G1FEPD
 楼主| 发表于: 2018-12-10 16:05:10
087:  VCCIO: 3.3V
088:  Read timeout.
089:  eMMC OCR: 0000
090:  eMMC CID:  000000000000000000000000000000
091:  eMMC CSD: 000000000000000000000000000000
 楼主| 发表于: 2018-12-10 18:58:35
什么不清楚
发表于: 2018-12-10 19:50:25
Thank you for your post
发表于: 2018-12-11 09:07:00
 楼主| 发表于: 2018-12-11 12:39:34
help connect rt809h  CV338H-T42
GMT+8, 2026-3-23 21:58 , Processed in 0.057851 sec., 12 queries .
