查看: 4090|回复: 10
康佳LED49K70A MSD6A818平台-打开串口引导程序
发表于: 2018-9-13 00:03:41
康佳LED49K70A MSD6A818平台引导程序
GD25Q16
35019475
72000546y
此程序串口已打开,可以方便使用串口进行升级,
正常使用请将串口关闭,以免影响机子的运行速度!
发表于: 2018-9-13 07:21:12
谢谢你的分享!
发表于: 2018-9-13 09:21:34
谢谢楼主分享
 楼主| 发表于: 2018-9-15 00:01:31
在控制台的状态下,输入 du 按回车,就可以关闭串口!
发表于: 2018-9-15 08:35:40
谢谢楼主分享
 楼主| 发表于: 2018-9-15 22:37:48
2018-9-12, 21:31:5
COM9, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
UART_115200
[AT][MB][start sb][0]
AC_ON
AutoDQS0-[3456789ABCD][3456789ABCDE][3456789ABCD][23456789ABC]-[0x7888]
AutoDQS1-[456789ABCDE][456789ABCDE][23456789ABCD][23456789ABC]-[0x7799]
BIST0-OK
BIST1-OK
_U[AT][MB][start ub][347]
U-Boot 2011.06-svn3304 (May 29 2014 - 09:44:13)
CPU  : Nike
Board: BD_MST049B_10AQV_NIKEC
Hello U-Boot
DRAM:  458 MiB
SPI:  Flash is detected (0x0B01, 0xC8, 0x40, 0x15)
spi_init: cfg_env_offset: 0x1e0000, at 560
uboot held at [3b6ddf60~3ca00000]
Now running in RAM - U-Boot at: 3bb00000
MMC:        eMMC 3775MB [75FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Get MAC from ethaddr env
MAC:  0x0: 0x1a: 0x34: 0xf9:0x44: 0x81
It's the last cmd
msIR_Initialize
Wait for PM51 standby...........PM51 run ok
--------------待机打印。
...........UART_115200
[AT][MB][start sb][0]STR_DC_ON
_U[AT][MB][start ub][290]
CPU  : Nike
Hello U-Boot
DRAM:  458 MiB
In:    serial
Out:   serial
Err:   serial
It's the last cmd
msIR_Initialize
Wait for PM51 standby DRAM ...........PM51 run ok...........============= set bootargs ===============
Unknown command 'if_51OnRam_set' - try 'help'
Hit any key to stop autoboot:  1  0
fore uup IRKey [0xff]
mingwu_mboot----------get_boot_mode_from_env
mingwu_mboot------------>get_boot_mode_from_env-->ulComplete == 0
MDrv_PNL_Init u32PnlRiuBaseAddr = 1f200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1f000000
[_MDrv_PNL_Init_LPLL][300]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][302]u16HTotal=2200,u16VTotal=1125,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1125, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][345]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][347]u16HTotal=2200,u16VTotal=1125,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1125, u16DefaultVFreq=600
Init PWM1Init PWM2[ERROR] No Support PWM Clock Unit Divider in Nike Platform[AutoTest][MBoot][JPD Decode]
发表于: 2018-11-17 13:53:59
谢谢楼主分享
发表于: 2019-4-23 18:57:57
己下载,试机正常,确实有用,顶
发表于: 2020-2-23 20:31:28
下载了明天写进去试试
GMT+8, 2026-3-20 09:24 , Processed in 0.053569 sec., 9 queries .
