查看: 1691|回复: 3
RT809H MX29GL128E burn problem
发表于: 2018-7-2 22:01:10
Hello...
I want to program the MX29GL128E chip with my RH809H
but I am constantly warning that the chip is not empty.
What is this solution?
Please help me with this.
otherwise I will regret taking the device ...
发表于: 2018-7-13 16:55:53
Привет. Если ещё актуально. Возможно, низкое напряжение по линии USB. Вариант попробовать на другом PC. Или подключить дополнительный блок питания... Встречал такие бсуждения именно по TSOP-56. MX29gl128e упоминается. Хотя проблема была именно в работе со всеми TSOP-56 чипами.
Hey. If it's still relevant. Possibly low voltage on the USB line. Option to try on another PC. Or connect an additional power supply ... I met such discussions using TSOP-56. MX29gl128e mentioned. Although the problem was precisely with all TSOP-56 chips.
发表于: 2018-7-5 07:58:36
不知道是哪个国家的人,不告诉你怎么写这个芯片,就后悔买了809H,真是笑话;换句话就是要退货的意思了。
发表于: 2018-7-12 22:35:56
老外也不易啊,犹如国人使用外国造仪器一样蒙,语言不通,理解更难!用过RT809H的人就知道,如果是拆下FLASH进行操作的,请检查这只56脚的FLASH引脚接触是否良好!否则是FLASH部分区域只读或加密(真是这样的话建议不要去写或擦除了,不然会后悔!),如果判断是坏块造成的,可以用直刷(Write)试试;如果是在线读写的,可能是苾片组方案不匹配或主板有故障!
Foreigners also not easy, just as americans use foreign made instrument, the language, understand more difficult! Used RT809H people will know that, if it's manipulation, remove the FLASH, please check it only 56 feet FLASH pin contacts are in good condition! It is FLASH parts read-only or encryption (so not recommended to write or erased, or you will regret!) , if the judge is caused by bad block, can brush with straight (Write) a try; If it is to read and write online, the likelihood is Bi group scheme does not match or motherboard is faulty.
注:网上翻译,不知这位外国朋友能看懂不  :)     Online translation, I do not know the foreign friends can understand
GMT+8, 2026-3-21 03:45 , Processed in 0.059486 sec., 13 queries .
