查看: 1417|回复: 4
一个创维49寸安卓机 开机灰屏 谁看得懂打印信息 帮我看下正常吗 在线等
发表于: 2018-6-30 20:50:41
如题U-Boot 2012.07-svn12491 (Sep 28 2014 - 12:56:45)
GPU : BISR testing...
GPU : Finish BISR testing (OK)
SCPU: BISR testing ....
SCPU: Finish BISR testing
CPU  : Cortex-A9 dual core
Media: eMMC BP0
MISC : set FUSE_RDY
MISC: efuse had NOT been written
[krsv] use default uboot memory:
DRAM:  2 GiB
Watchdog: Enabled
init_amp_prepare
name=AMP_I2C ppcb_enum.Name=AMP_I2C, ppcb_enum.info=300061b48
AMP_I2C=12884901889
name=AMP_DEVICE_ADDR ppcb_enum.Name=AMP_DEVICE_ADDR, ppcb_enum.info=1b00061b18
name=PIN_AMP_MUTE ppcb_enum.Name=PIN_AMP_MUTE, ppcb_enum.info=1790300061b28
no PIN_MISC_951_RST
Board: Tv010 v2 2G Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
MMC:
emmc:mmc_initial(1) Sep 28 2014 12:57:14
RTD299x eMMC: 0
Device: RTD299x eMMC
Manufacturer ID: 90
OEM: 14a
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Extern param: MMC blk:0x7c (to 0x9000)
         rtk_eMMC_read blk_addr=0x0000007c, data_size=0x00000800, buffer=0x00009000
Factory: MMC
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000d433, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000f435, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00286600, buffer=0x0a900000
Factory: seq:0x1621, blk:0xc000(pp:0), size:0x286600 (to 0xa900000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=1
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN=0
BOOT_PAL_NTSC_100_120_HZ=0
boot_power_on_mode=1
get_layout:
------------tmp/factory/layout.txt found
BOOTPART=0
TAG=21
init_amp
Panel: Use parameters in tmp/factory/bin_panel/panel.bin
Panel: lg_49_4k2k_vby1_m+
panel_init_1st
Panel: ulFreq:148500000, nDPLL:157499520, Mcode:35, Ncode:3, offset:751
================== P_VBY1_4K2K condition ===================
***** Get Chip ID (3) *****
================== VBY_ONE_PANEL_CHINA_STAR_4K2K_VBY1 ===================
DispI : Finish BISR testing done
DispD : Finish BISR testing done
Panel_Custom_INDEX=6
In:    serial
Out:   serial
Err:   serial
Net:   rtl8139: REALTEK RTL8139 @0xb8016000
Hit Esc or Tab key to enter console mode or rescue linux:  0
------------bootloader message size is 1088
======== Checking into android recovery ====
boot_ac_on=1
stopping USB..
Start Boot Setup ...
[eMMC]STR value:0x0,0x0
No STR...
REG 0xb8060100 : 0x0
JUMP address: 0x0
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000020, buffer=0x0a820000
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000400, buffer=0x0a820000
         FW Table to 0x0a820000, size=0x00000400 (0x0a820400)
         FW Table fr 0x02000000, fw count: 6
part_entry[0].len 0xd2000000
fw_desc_table_v1.paddings 0x400
fw_total_paddings 0x1090400
eMMC_bootcode_area_size0x1800000
EMMC_FACTORY_SIZE 0x800000
g_u32STDsize 0xcef6f800, g_u32STDoffset 0x3090800
blkNO 0x20000, 0x4000000, 0x200, 0x1
         rtk_eMMC_read blk_addr=0x00020000, data_size=0x00001000, buffer=0x00062960
STD identifier NOT match, enter normal boot!!
Normal boot fw follow...
Linux Kernel:
         FW Image to 0x00108000, size=0x00ac4104 (0x00bcc104)
         FW Image fr 0x02008000 (non-lzma)
Audio FW:
         FW Image to 0x81700000, size=0x0020b090 (0x8190b090)
         FW Image fr 0x02acc200 (non-lzma)
         rtk_eMMC_read blk_addr=0x00015661, data_size=0x0020b090, buffer=0x01700000
         emmc block_no=0x00015661
         flash_to_ram_addr=0x01700000
         imageSize=0x0020b090
         FW Image checksum FAILED
         FW Image entry  checksum=0x0a2c60bb
         FW Image result checksum=0x0a2c6edb
dump ddr data(base=0x01700000)
000 : 10 00 00 63 00 00 00 00 10 00 00 61 00 00 00 00
010 : 5f 5f 67 68 73 65 6e 64 5f 62 73 73 81 90 b0 91
020 : 41 55 54 48 bd 61 01 21 00 00 00 00 00 00 00 00
030 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
040 : 08 5c e0 5a 00 00 00 00 00 00 00 00 00 00 00 00
050 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
060 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
070 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
080 : 08 5c e0 5a 00 00 00 00 00 00 00 00 00 00 00 00
090 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0a0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0b0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0c0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0d0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0e0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0f0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 : 08 5c e0 5a 00 00 00 00 00 00 00 00 00 00 00 00
110 : 00 00 00 00 00 00 00 00 81 73 f0 28 00 00 00 00
120 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140 : 08 5c e0 5a 00 00 00 00 00 00 00 00 00 00 00 00
150 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180 : 08 5c e0 5a 00 00 00 00 00 00 00 00 00 00 00 00
190 : 40 14 60 00 00 00 00 00 3c 01 ff fc 34 21 ff fe
1a0 : 02 81 40 24 3c 01 30 00 01 01 40 25 3c 01 ff ff
1b0 : 34 21 00 ff 01 01 40 24 40 88 60 00 3c 08 08 00
1c0 : 40 88 68 00 00 80 a8 21 00 a0 b0 21 00 c0 b8 21
1d0 : 3c 1d 81 8f 27 bd de 00 3c 1c 81 91 27 9c b0 90
1e0 : 0c 5c 00 b5 24 04 00 01 0c 5c 00 b5 24 04 00 00
1f0 : 3c 08 81 91 25 08 b0 90 3c 09 81 91 25 29 b0 91
panel_init_2nd
ampinit at panel flow, 3142
AMP_I2C=12884901889
no PIN_MISC_951_RST
#####m_AMP_DEVICE_ADDR = 0x1b00000000,m_I2C_MASTER = 0x300000000,m_PIN_AMP_MUTE = 0x1790300000000, m_PIN_AMP_RST = 0x1
init TAS5707_HAIER
m_AMP_DEVICE_ADDR = 0x1b000a4275,m_I2C_MASTER = 0x300000000,m_PIN_AMP_MUTE = 0x1790300000000, m_PIN_AMP_RST = 0x1
ee read 368, 6
name=EEP_I2C ppcb_enum.Name=EEP_I2C, ppcb_enum.info=400061b78
EEP_I2C=17179869185
name=EEP_DEVICE_ADDR ppcb_enum.Name=EEP_DEVICE_ADDR, ppcb_enum.info=5000061b58
name=PIN_EEP_WP ppcb_enum.Name=PIN_EEP_WP, ppcb_enum.info=1130400061b68
m_PIN_EEP_WP = 0x1130400078b30
a. Eeprom_Read-macaddr is bcec2310b682
 set_mac_cmd is bc:ec:23:10:b6:82
#@# do_usb(481) is_usb_ac_on 0
(Re)start USB...
USB0:   #@# usb3_phy_setting(108) +++ 20130826
#@#  usb3_phy_setting(209) ---
#@# usb2_phy_setting(214) +++ 20130823-1
#@#  usb2_phy_setting(322) ---
#@#  usb3_mac_setting(329) +++ 20130510
#@#  usb3_mac_setting(412) ---
Register 5000140 NbrPorts 5
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... usb_init 104
ERROR: Invalid USB IF length (221)
ERROR: Configure Endpoint command returned completion code 8.
Failed to configure xHCI endpoint
failed to set default configuration len 177, status 80000000
#@# usb_hub_configure(515) skip the device in usb3 port 5!
usb_init 113
2 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
** Invalid boot device **
pUsbFirstFileName = NULL
stopping USB..
Enter console mode, disable watchdog ...
Realtek>
发表于: 2018-6-30 21:13:57
U盘刷主程序
 楼主| 发表于: 2018-6-30 21:29:55
谢谢 打印信息里面显示了主程序错误吗
 楼主| 发表于: 2018-6-30 23:09:16
U盘刷好了  。。。
发表于: 2018-6-30 23:12:44
Thank you for your post.
GMT+8, 2026-3-16 20:41 , Processed in 0.047786 sec., 10 queries .
