查看: 3386|回复: 3
海信LED55K5100U卡在LOG
发表于: 2018-6-2 09:29:08
请各位师傅帮帮忙海信LED55K5100U卡在LOG串口打印如下Bootrom startBoot from eMMC
Starting fastboot ...
System startup
Fastboot 3.3.0 (gfkfcmo@ubuntu-CI-1) (Apr 22 2016 - 15:47:45)
Fastboot:      Version 3.3.0
Build Date:    Apr 22 2016, 15:48:09
CPU:           Hi3751v600
Boot Media:    eMMC
MMC/SD controller initialization.
MMC/SD Card:
    MID:         0x11
    Read Block:  512 Bytes
    Write Block: 512 Bytes
    Chip Size:   3776M Bytes (High Capacity)
    Chip Type:   MMC
    Version:     4.0
    Speed:       25000000Hz
    Bus Width:   8bit
    Boot Addr:   0 Bytes
The DDR memory layout:
      page table: 0x0c000000 - 0x0c400000  4 MiB
           stack: 0x0c400000 - 0x0c800000  4 MiB
     global data: 0x0cbfffc4 - 0x0cc00000  60 Bytes
          malloc: 0x0cc00000 - 0x10c00000  64 MiB
           .text: 0x10c00000 - 0x10c7f304  508.8 KiB
            data: 0x10c7f304 - 0x10d97f44  1.1 MiB
Boot Env on eMMC
    Env Offset:          0x00100000
    Env Size:            0x00010000
    Env Range:           0x00010000
BootMode = MEM:[0],AC
PowerOn!
CUSTOM Func[HI_DRV_CUSTOM_BoardInit] Line[144] :Board Name is HISENSE_HI3751V600_K300_BOARD
power_btwifi onoff.
power_ir_led.
DISP0, YPbPR:[0, 0, 0]
DISP0, CVBS:3
DISP0:fmt:6, pixelfmt:9, offset:[0, 0, 0, 0], stAspectRatio:[2, 0, 0]
DISP0:srcdisp:1, virscreen:[3840, 2160], BGColor:[0, 0, 0], kinds of degree:[B:50, C:50, H:50, S:50]
DISP1, YPbPR:[1, 2, 0]
DISP1, CVBS:0
DISP1:fmt:6, pixelfmt:9, offset:[0, 0, 0, 0], stAspectRatio:[2, 0, 0]
DISP1:srcdisp:1, virscreen:[3840, 2160], BGColor:[0, 0, 0], kinds of degree:[B:50, C:50, H:50, S:50]
DISP0, CVBS:3
DISP1, CVBS:0
DISP_HAL_Get_PanelCfgPara PanelInfo: Width 3840 Height 2160 HSyncWidth 360 HsyncFP 200 VSyncWidth 60 VsyncFP 30
Vb1 u32Clk=891000000, u32IntPart=0x1002094, u32MinorPart=0x12800000
HPLL Lock Success u32Tmp=8
HPLL Lock Success u32Tmp=1
vbo_para_cksel=0x2, vbo_div_cksel=0x3 vo_hd_tv_cksel=2 lvds_cken=1, vbo_div_cken=0, vbo_para_cken=0, vbo_para_phy_pctrl=0
u32PixelClk=594000000, HpllTargetClk=891000000,u32HpllCtrl0=0x12800000, u32HpllCtrl1=0x1002094
Set Disp 1 SyncInfo: V (30, 60, 2160) H (200, 360, 3840)
Spread Info: <IntfType:VBO, SpreadOn:1, SpreadRatio:0, SpreadFreq:2>
tag is: version=1.0.0.2 baseparam=0x5fffc000,0x2000 SR_ZME_COEF=0x5fffa000,0x1000 panelparam=0x5fff4000,0x5000 SR_ZME_COEF=0x5fff2000,0x1000 HIFB_ZmeCoef=0x5feb8000,0x3000 HIFB_DispBuf_HD=0x5df13000,0x1fa4000
Enter recovery!
recovery_boot_args:mem=1536M console=ttyAMA0,115200 blkdevparts=mmcblk0:1M(fastboot),1M(bootargs),10M(recovery),2M(deviceinfo),8M(baseparam),8M(panelparam),80M(logo),40M(kernel),20M(misc),1024M(system),2206M(userdata),80M(dtv),20M(atv),10M(tmp),100M(cache),10M(bootmusic),80M(logoext) mmz=ddr,0,630M,510M vmalloc=680M
mmc read stop failed!
HI_Flash_Read partion recovery error
HI_DRV_I2C_Exit,478: hi_i2c Release success.
mac:080:B7:C2:B9D
power_btwifi onoff.
Reserve Memory
    Start Addr:          0x5FFFF000
    Bound Addr:          0x13D98000
    Free  Addr:          0x5BC70000
    Alloc Block:  Addr        Size
                  0x5BC70000       3133440
                  0x5BF6E000       33177600
                  0x5DF13000       33177600
                  0x5FEB8000       12288
                  0x5FEBC000       1048576
                  0x5FFBD000       212992
                  0x5FFF2000       4096
                  0x5FFF4000       20480
                  0x5FFFA000       4096
                  0x5FFFC000       8192
Press Esc to stop autoboot
MMC read: dev # 0, block # 225280, count 20480 ...
发表于: 2018-6-2 16:39:18
没明白楼主是啥意思,你是想把打印信息完全搞明白?这个我不行,期待高手路过,不过这种故障用U盘升级主程序就能修好
 楼主| 发表于: 2018-6-2 19:41:50
顺鑫电子 发表于 2018-6-2 16:39
没明白楼主是啥意思,你是想把打印信息完全搞明白?这个我不行,期待高手路过,不过这种故障用U盘升级主程 ...
按音量减键没有出现升级提示   刷机包是淘宝上买的
发表于: 2018-6-3 08:37:11
找卖家 要升级方法 ,你的可能是EMMC 问题  ,要换一块试试看吧
GMT+8, 2026-4-9 17:51 , Processed in 0.062293 sec., 9 queries .
