查看: 1578|回复: 2
NAND02GW3B2DN6
发表于: 2018-5-29 14:44:27
hi i need some help.
I have a DVD player (Philips BDP7600/12) wich no boot and its stack to Philips logo.
My opinion is that have firmware problem but unfortunately i can't upgrade it or downgrade it without menu settings. The DVD have NAND02GW3B2DN6@TSOP48.
The newer version of RT809H supports:
ST  NAND128W3A@TSOP48
ST  NAND256W3A@TSOP48
ST  NAND512W3A@TSOP48
ST  NAND01GW3A@TSOP48
ST  NAND01GW3B2BN6@TSOP48
ST  NAND02GW3B2DN6@BGA63
ST  NAND04GW3B2DN6@TSOP48
my question is can it support NAND02GW3B2DN6@TSOP48 with similar nand?
 楼主| 发表于: 2018-5-31 19:45:14
Any help?
What to select to read NAND02GW3B2DN6@TSOP48
 楼主| 发表于: 2018-6-26 22:48:41
The RT809H can properly read/write the NAND02GW3B2DN6@TSOP48 i tried and it's done.
I can't fix the DVD because the file i have read it's with bootloader and other stuffs and i have only the update bin file which i don't know how to embeded to fix it.
GMT+8, 2026-3-21 05:18 , Processed in 0.053072 sec., 11 queries .
