查看: 3313|回复: 1
海信LED55EC520UA RSAG7.820.6299/ROHD打印信息
发表于: 2018-5-8 16:26:42
海信LED55EC520UA打印信息如下,请帮分析一下哪的故障
Bootrom start
Boot from eMMC
Starting fastboot ...
System startup
Fastboot 3.3.0 (gfkfcmo@) (Jul 15 2016 - 17:47:01)
Fastboot:      Version 3.3.0
Build Date:    Jul 15 2016, 17:47:16
CPU:           Hi3751v600
Boot Media:    eMMC
MMC/SD controller initialization.
MMC/SD Card:
    MID:         0x15
    Read Block:  512 Bytes
    Write Block: 512 Bytes
    Chip Size:   3728M Bytes (High Capacity)
    Chip Type:   MMC
    Version:     4.0
    Speed:       25000000Hz
    Bus Width:   8bit
    Boot Addr:   0 Bytes
The DDR memory layout:
      page table: 0x0c000000 - 0x0c400000  4 MiB
           stack: 0x0c400000 - 0x0c800000  4 MiB
     global data: 0x0cbfffc4 - 0x0cc00000  60 Bytes
          malloc: 0x0cc00000 - 0x10c00000  64 MiB
           .text: 0x10c00000 - 0x10c7f31c  508.8 KiB
            data: 0x10c7f31c - 0x10d97f44  1.1 MiB
Boot Env on eMMC
    Env Offset:          0x00100000
    Env Size:            0x00010000
    Env Range:           0x00010000
BootMode = MEM:[0],AC
PowerOn!
CUSTOM Func[HI_DRV_CUSTOM_BoardInit] Line[144] :Board Name is HISENSE_HI3751V600_K300_BOARD
power_btwifi onoff.
power_ir_led.
DISP0, YPbPR:[0, 0, 0]
DISP0, CVBS:3
DISP0:fmt:6, pixelfmt:9, offset:[0, 0, 0, 0], stAspectRatio:[2, 0, 0]
DISP0:srcdisp:1, virscreen:[3840, 2160], BGColor:[0, 0, 0], kinds of degree:[B:50, C:50, H:50, S:50]
DISP1, YPbPR:[1, 2, 0]
DISP1, CVBS:0
DISP1:fmt:6, pixelfmt:9, offset:[0, 0, 0, 0], stAspectRatio:[2, 0, 0]
DISP1:srcdisp:1, virscreen:[3840, 2160], BGColor:[0, 0, 0], kinds of degree:[B:50, C:50, H:50, S:50]
DISP0, CVBS:3
DISP1, CVBS:0
####search the mouse is okinit: get_cts_mode = 0
healthd: No charger supplies found
healthd: BatteryStatusPath not found
healthd: BatteryHealthPath not found
healthd: BatteryPresentPath not found
healthd: BatteryCapacityPath not found
healthd: BatteryVoltagePath not found
healthd: BatteryTemperaturePath not found
healthd: BatteryTechnologyPath not found
binder: 1491:1491 transaction failed 29189, size 0-0
init: cannot find '/system/bin/rild', disabling 'ril-daemon'
init: cannot find '/system/bin/dbus-daemon', disabling 'dbus'
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[vaudio]: fill_void_pcm_data : stop
[vaudio]: fill_void_pcm_data : start
init: cannot find '/system/bin/frontPanel', disabling 'frontPanel'
init: cannot find '/system/bin/dtvserver', disabling 'dtvserver'
init: cannot find '/system/bin/hidns-sd', disabling 'hidns-sd'
init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
init: powerctl: cannot expand '${sys.powerctl}'
init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
root@Hi3751:/ # tntfs: module license 'Commercial. For support email ntfs-support@tuxera.com.' taints kernel.
Disabling lock debugging due to kernel taint
Tuxera NTFS driver 3014.6.29.1 [Flags: R/W MODULE].
create enforce
init: untracked pid 1484 exited
input: Smart_TV_Keypad as /devices/virtual/input/input7
[419658377 ERROR-HI_AO]:SND_SetOpHdmiMode[1692]:OutPort(4) not attatch this card
[419658387 ERROR-HI_AO]:SND_SetOpHdmiMode[1692]:OutPort(4) not attatch this card
#####UPDATE EDID!
#####UPDATE EDID!
#####UPDATE EDID!
###start HDCP
[419658566 ERROR-HI_AO]:AO_SND_Open[506]:port(80) is aready attatched.
FC 0 WI 1 DA 1 WF 1 bMC 0 bMA 0 b3DC 0
[419658662 ERROR-HI_I2C]:I2C_DRV_WaitWriteEnd[129]:wait write data timeout!
[419658669 ERROR-HI_I2C]:I2C_DRV_Write[232]:I2C_DRV_Write I2cNum 1 I2cDevAddr 0x38 I2cRegAddr 0x43 I2cRegAddrByteNum 1 timeout!
[419658680 ERROR-HI_I2C]:I2C_DRV_WaitWriteEnd[129]:wait write data timeout!
[419658687 ERROR-HI_I2C]:I2C_DRV_Write[232]:I2C_DRV_Write I2cNum 1 I2cDevAddr 0x38 I2cRegAddr 0x9d I2cRegAddrByteNum 1 timeout!
Spread Info: <IntfType:VBO, SpreadOn:1, SpreadRatio:0, SpreadFreq:2>
Spread Info: <IntfType:VBO, SpreadOn:1, SpreadRatio:4, SpreadFreq:2>
Spread Info: <IntfType:VBO, SpreadOn:1, SpreadRatio:4, SpreadFreq:4>
发表于: 2025-1-24 20:24:14
楼主这个打印信息 是什么故障
GMT+8, 2026-4-5 00:55 , Processed in 0.047018 sec., 10 queries .
