查看: 1458|回复: 8
康佳LED55R5600PF无限重启。卡LOGO求助
发表于: 2018-4-18 21:18:31
康佳LED55R5600PF无限重启,卡LOGO求助。用U盘强刷程序,进入升级条马上退出升级。附打印信息,求大家帮分析下看是哪的问题。。。。2018-4-18, 20:31:36 COM9, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F: UART_115200[AT][MB][start sb][0]AC_ONAutoDQS0-[3456789ABCDE][456789ABCDE][3456789ABCD][23456789ABC]-[0x7898]AutoDQS1-[456789ABCDEF][56789ABCDE][3456789ABCD][23456789ABCD]-[0x7899]BIST0-OKBIST1-OK_U[AT][MB][start ub][341]U-Boot 2011.06-svn2307 (Nov 11 2013 - 16:45:46)CPU  : NikeBoard: BD_MST049B_10AQV_NIKEHello U-BootDRAM:  458 MiBSPI:  Flash is detected (0x0711, 0xEF, 0x40, 0x15)spi_init: cfg_env_offset: 0x1e0000, at 560uboot held at [3b6ddf60~3ca00000]Now running in RAM - U-Boot at: 3bb00000MMC:        eMMC 3775MB [75FFF8h] UART BUS OFF!!UART_115200[AT][MB][start sb][0]AC_ONAutoDQS0-[3456789ABCDE][456789ABCDE][23456789ABC][23456789ABC]-[0x7798]AutoDQS1-[456789ABCDEF][56789ABCDE][3456789ABCD][23456789ABCD]-[0x7899]BIST0-OKBIST1-OK_U[AT][MB][start ub][341]U-Boot 2011.06-svn2307 (Nov 11 2013 - 16:45:46)CPU  : NikeBoard: BD_MST049B_10AQV_NIKEHello U-BootDRAM:  458 MiBSPI:  Flash is detected (0x0711, 0xEF, 0x40, 0x15)spi_init: cfg_env_offset: 0x1e0000, at 560uboot held at [3b6ddf60~3ca00000]Now running in RAM - U-Boot at: 3bb00000MMC:        eMMC 3775MB [75FFF8h] UART BUS OFF!!UART_115200[AT][MB][start sb][0]AC_ONAutoDQS0-[3456789ABCDE][456789ABCDE][3456789ABC][23456789ABC]-[0x7798]AutoDQS1-[456789ABCDEF][56789ABCDE][3456789ABCD][23456789ABCD]-[0x7899]BIST0-OKBIST1-OK_U[AT][MB][start ub][341]U-Boot 2011.06-svn2307 (Nov 11 2013 - 16:45:46)CPU  : NikeBoard: BD_MST049B_10AQV_NIKEHello U-BootDRAM:  458 MiBSPI:  Flash is detected (0x0711, 0xEF, 0x40, 0x15)spi_init: cfg_env_offset: 0x1e0000, at 560uboot held at [3b6ddf60~3ca00000]Now running in RAM - U-Boot at: 3bb00000MMC:        eMMC 3775MB [75FFF8h] UART BUS OFF!!
 楼主| 发表于: 2018-4-18 21:20:50
UART BUS OFF!!
发表于: 2018-4-18 21:44:27
UART BUS OFF!!  这个显示不正常,卡LOGO  去TB购买数据刷机吧,自己下载的都不管用哦...U盘至少要准备3个 4G的,809H编程器一台   都有了基本就可以解决问题了...
 楼主| 发表于: 2018-4-18 21:48:12
在TB买了数据,也一样。刷不成功。
 楼主| 发表于: 2018-4-18 21:49:17
ahsztiancl 发表于 2018-4-18 21:44
UART BUS OFF!!  这个显示不正常,卡LOGO  去TB购买数据刷机吧,自己下载的都不管用哦...U盘至少要准备3个  ...
只有809F.......................
发表于: 2018-4-19 08:51:19
809F刷引导程序,在用U盘升级主程序。论坛里有教程 自己去看看吧...
 楼主| 发表于: 2018-4-19 10:43:16 来自手机
同求此机的引导程序
来自: 微社区
发表于: 2018-5-16 12:14:41
这个电源故障,不是程序问题!
GMT+8, 2026-3-21 05:18 , Processed in 0.053679 sec., 10 queries .
