查看: 2383|回复: 5
谁有T.MS608.61的程序?
发表于: 2018-1-4 17:36:28
谁有T.MS608.61的程序?屏:M236H-L01    客户家只有宽带信号。gys-wj@126.com     QQ:779605331
发表于: 2018-1-4 18:09:10
I don't know what you mean. So I can't suggest you.
 楼主| 发表于: 2018-1-4 18:21:38
客户不同意换别的通用板,如果还换这个板的话代价高了。想刷刷程序看看有没有效果。
发表于: 2018-1-5 11:38:55
我没有呢,看看那位有一个吧
 楼主| 发表于: 2018-1-24 10:10:45
是硬件坏了,在马云家买了一块就好了。这个板子读取打印信息有点乱码。故障板的打印信息:
2018-1-22, 2:8:23
COM7, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
?K殨丧叡5)z昭閬殨丧叡5)*缮閬殨丧叡5)r曆閬r絹曆?晒曆仚秸箲?R:曆?
仚山祦曆?憫蓙暪?)j
閬偮灵偮烧?偮迳?偮憤榱螺鸵偮偕jRNo USB is connecting
usb init failed
Check USB port[2]:
Host type:2
scanning bus for devices...
[USB] interface[0] conf:1 value 8:
1 USB Device(s) found
       scanning bus for storage devices... bulk max packet size: ep 200 ep2 200
max lun:0
1 Storage Device(s) found
reading /FAC_BOOT_6A608.cvt
** Unable to read  **
FAC_BOOT_parser--->failed
MstarProcess
=key index:1
Check USB port[2]:
Host type:2
max lun:0
         Creat Timer Success,TimerId = 0
cmd: fatload usb 0:0  40200000 /Mboot.bin 1
** Partition 0 not valid on device 0 **
** Unable to use usb 0:0 for fatload **
cmd: fatload usb 0:1  40200000 /Mboot.bin 1
reading /Mboot.bin
** Unable to read "/Mboot.bin" from usb 0:1 **
cmd: fatload usb 0:2  40200000 /Mboot.bin 1
** Partition 2 not valid on device 0 **
** Unable to use usb 0:2 for fatload **
cmd: fatload usb 0:3  40200000 /Mboot.bin 1
** Partition 3 not valid on device 0 **
** Unable to use usb 0:3 for fatload **
cmd: fatload usb 0:4  40200000 /Mboot.bin 1
** Partition 4 not valid on device 0 **
** Unable to use usb 0:4 for fatload **
cmd: fatload usb 1:0  40200000 /Mboot.bin 1
** Invalid boot device **
cmd: fatload usb 1:1  40200000 /Mboot.bin 1
cmd: fatload usb 1:2  40200000 /Mboot.bin 1
cmd: fatload usb 1:3  40200000 /Mboot.bin 1
cmd: fatload usb 1:4  40200000 /Mboot.bin 1
cmd: fatload usb 2:0  40200000 /Mboot.bin 1
cmd: fatload usb 2:1  40200000 /Mboot.bin 1
cmd: fatload usb 2:2  40200000 /Mboot.bin 1
cmd: fatload usb 2:3  40200000 /Mboot.bin 1
cmd: fatload usb 2:4  40200000 /Mboot.bin 1
Notic : no Mboot.bin file in usb
cmd: fatload usb 0:0  40200000 /MstarUpgrade.bin 1
cmd: fatload usb 0:1  40200000 /MstarUpgrade.bin 1
reading /MstarUpgrade.bin
1 bytes read
16384 bytes read
mmc change mount : tvcustomer
 src/MsUpgradeUtility.c:dont_overwrite_force_enable:
>> mmc slc 0 1
SLC mode or reliable write has been set, slc size is 0 bytes
>> mmc rmgpt
[ eMMC_FCIE_PollingEvents() ] eMMC Err: 10000000 us, Reg.0000h: 0002h, but wanted: 4800h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 Reg.12: FF60h, Err: 80000005h, Retry: 1
eMMC retry by DATA_SYNC: 0h, ori:55h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 Reg.12: FF68h, Err: 80000005h, Retry: 2
eMMC Warn: slow SDR clk to 5h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 Reg.12: FF68h, Err: 80000005h, Retry: 3
eMMC retry by DATA_SYNC: 40h, ori:15h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 Reg.12: FF68h, Err: 80000005h, Retry: 4
eMMC Warn: slow SDR clk to 4h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 Reg.12: FF68h, Err: 80000005h, Retry: 5
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 Reg.12: FF68h, Err: 80000005h, Retry: 6
eMMC Warn: slow SDR clk to 2h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 Reg.12: FF68h, Err: 80000005h, Retry: 7
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 Reg.12: FF68h, Err: 80000005h, Retry: 8
eMMC Warn: slow SDR clk to 1h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 Reg.12: FF68h, Err: 80000005h, Retry: 9
GMT+8, 2026-3-24 06:13 , Processed in 0.055160 sec., 10 queries .
