查看: 3326|回复: 3
创维40E360E8S16机芯打印信息
发表于: 2017-12-20 19:23:28
UART_115200
BIST0-OK
[0123456789AB][0123456789AB][123456789ABC][123456789ABC]-5566
U[AT][MB][start ub][391]
U-Boot 2011.06 (Nov 15 2013 - 02:49:39)
DRAM:  256 MiB
Hello U-Boot
Stack Pointer at: 87e3cc40
uboot held at [8f000000~90000000]
Now running in RAM - U-Boot at: 871f0180
NAND:  DMA MODE
[NC_Init]       SDR NAND is detected
CIS is found @Blk0
FCIE is set to 54MHz
128 MiB
*** Warning - set default for mtdparts, using default environment
Creating 1 MTD partitions on "nand0":
0x000000640000-0x000000840000 : "mtd=2"
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
nand_read_bbt: Bad block at 0x000006000000
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: attached mtd1 to ubi0
UBI: MTD device name:            "mtd=2"
UBI: MTD device size:            2 MiB
UBI: number of good PEBs:        16
UBI: number of bad PEBs:         0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    250
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             1
UBI: total number of reserved PEBs: 15
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 13/10
NAND read: device 0 offset 0x180000, size 0xa8
168 bytes read: OK
Volume "MPOOL" found at volume id 0
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Set MAC default
MAC:  0x0: 0x30: 0x1b: 0xba:0x2: 0xdb
UBI: mtd1 is detached from ubi0
incorrect device type in UBI
Partition UBI not found!
0x000000180000-0x0000003e0000 : "mtd=0"
UBI error: ubi_read_volume_table: the layout volume was not found
UBI error: ubi_init: cannot attach mtd1
UBI error: ubi_init: UBI error: cannot initialize UBI, error -22
UBI init error 22
0x0000003e0000-0x000000640000 : "mtd=1"
UBI init error 22
UBIFS error (pid 0): ubifs_get_sb: cannot open "ubi:CONFIG", error -19
Error reading superblock on volume 'ubi:CONFIG'!
[ERROR] vfs_mount:214: error partition symbol
[ERROR] vfs_getsize:294: filesystem is not mounted
[ERROR] loadscript:744: No enough buffer or path fail(/sys.ini) :
[src/MsUtility.c] [loadscript]
UBI init error 22
UBI init error 22
UBIFS error (pid 0): ubifs_get_sb: cannot open "ubi:customer", error -19
Error reading superblock on volume 'ubi:customer'!
[ERROR] prepare_nand_dbtable:570:  get logo_size fail...>>>:0
[ERROR] write_dbtable:648: flash database not ready...>>>
[ERROR] do_dbtable_init:230: dbtable init fail
It's the last cmd
<NULL>
No recovery information, needless to recovery
Changelist:     00112233
[ERROR] set_bootargs_cfg:403: bootargs doesn't exist
[ERROR] set_panelinit_cfg:585: set BOOTLOGO_IN_MBOOT to bootargs fail
[ERROR] set_env_cfg:536: set ENV_VAR_OFFSET=0xD9000 to bootargs fail
[ERROR] set_security_cfg:494: set hsl=true to bootargs fail
Unknown command 'if_51OnRam_set' - try 'help'
AC on
u8adcValue = 0xff[ERROR] raw_read:510: len is zero
[ERROR] Read_PanelParaFromflash:1201: ERROR: Read_PanelParaFromflash fail...>>>
[ERROR] panel_dinit:363: panel_dinit: Read_PanelParaFromflash() failed, at 363
UBI init error 22
UBI init error 22
[ERROR] LoadMMAP:486: mount CONFIG fail
[ERROR] init_mmap:438: load mmap fail
[ERROR] get_mmap:411: init mmap fail
[ERROR] get_addr_from_mmap:343: get mmap fail
[ERROR] LoadMMAP:480: LoadMMAP fail last time, skip it!
[ERROR] do_bootlogo:623: Panle is not ready
Unknown command 'mmc' - try 'help'
nikon#
发表于: 2018-2-28 17:46:36
看不懂也,不过也支持一下
发表于: 2018-11-27 21:13:10
谢谢楼主分享!
GMT+8, 2026-2-2 17:44 , Processed in 0.051362 sec., 10 queries .
