查看: 2589|回复: 3
Haier LED Model: LE40B7000C
发表于: 2017-8-21 12:05:34
Chassis / Version: SIS231.PT71
Panel: V390HJ1-PE1
LED driver (backlight): integrated into MainBoard
Power Supply (PSU): integrated into MainBoard
MainBoard: TP.SIS231.PT71
IC MainBoard: CPU: SIS231, SPI Flash 25Q64
Model: V390HJ1-PE1
Type: a-Si TFT-LCD, CELL
Diagonal size: 39 inch
Resolution: 1920x1080, FHD
Display Mode: Super MVA, Normally Black, Transmissive
Active Area: 853.92x480 .33 mm
Surface: Antiglare (Haze 1%)
Glass Depth: 0.50 + 0.50 mm
Transmissivity: 5.8% (with Polarizer)
Contrast Ratio: 2000: 1
Display Colors: 16.7M (8-bit)
Response Time: 9.5 (G to G )
Frequency: 60Hz
Signal Interface: LVDS (2 ch, 8-bit), 51 pins
Voltage: 12.0V
发表于: 2017-8-21 13:00:43
谢谢您的分享
发表于: 2017-8-21 14:25:29
谢谢楼主分享
发表于: 2017-8-24 20:41:28
谢谢楼主分享,我English是数学老师教的。
GMT+8, 2026-2-3 07:01 , Processed in 0.051628 sec., 10 queries .
