查看: 2802|回复: 4
HAIER LED Model: LE32Z50
发表于: 2017-8-21 11:59:03
Chassis / Version: T.MS6M181.6A
Panel: T315XW06 V5
LED driver (backlight): integrated into PSU
PWM LED driver: BIT3251
Power Supply (PSU): MP123 - NW
PWM Power: PWM SOT23-6
MainBoard: T.MS6M181.6A
IC MainBoard: MST6M181VS-LF-Z1
TUNER: ET-9L1E-E01WP
Remote: HTR-D03
Brand: AUO
Model: T315XW06 V5
Type: a-Si TFT-LCD, Panel
Diagonal size: 31.5 inch
Resolution: 1366x768, WXGA
Display Mode: AMVA, Normally Black, Transmissive
Active Area: 697.685x392.256 mm
Surface: Antiglare (Haze 2%), Hard coating (3H)
Brightness: 350 cd / m2
Contrast Ratio: 3000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
Response Time: 6.5 (G to G)
Frequency : 60Hz
Lamp Type: WLED Embedded (LED Driver)
Signal Interface: LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
发表于: 2017-8-21 12:59:06
谢谢您的分享
发表于: 2017-8-22 17:36:56
谢谢楼主分享
发表于: 2017-8-25 16:36:46
Thanks for sharing
GMT+8, 2026-2-3 07:01 , Processed in 0.056793 sec., 9 queries .
