查看: 2580|回复: 2
Haier LED Model: LE24M600F Original
发表于: 2017-8-21 11:01:17
Panel: M240HTN01.0
T-CON: 24M09-C01 M240HTN01.0 CTRL BD; AUO-12304, AAT11732, AAT1301
LED driver (backlight): integrated into MainBoard
PWM LED driver: AP3039AM-G1
MOSFET LED driver: AO4468, MDD1951, MDD3754
Power Supply (PSU): integrated into MainBoard
PWM Power: OB2273 ( PWM SOT23-6 )
MOSFET Power: MDF4N65B
MainBoard: MSTV2409-ZC01-01
IC MainBoard: TSUMV59XUS, 25L3206E, RT7257EN, PT2308-S
Remote: HTR-A18H
Brand: AUO
Model: M240HTN01.0
Type: a-Si TFT-LCD, Panel
Diagonal size: 24.0 inch
Resolution: 1920x1080, FHD
Display Mode: TN, Normally White, Transmissive
Active Area: 531.36x298.89 mm
Surface: Antiglare, Hard coating (3H)
Brightness: 250 cd / m2
Contrast Ratio: 1000: 1
Display Colors: 16.7M (6 bit + Hi--FRC)
Response Time: 3.5 / 1.5 (Tr / Td)
Frequency: 60Hz
Lamp Type: 9S4P WLED Without Driver
Signal Interface: LVDS (2 ch, 8-bit), 30 pins
Voltage: 5.0V
发表于: 2017-8-21 14:41:52
谢谢楼主分享
发表于: 2017-8-22 15:46:30
谢谢楼主分享.
GMT+8, 2026-2-3 08:35 , Processed in 0.065472 sec., 10 queries .
