查看: 2733|回复: 5
海信32K1800打印信息
发表于: 2017-2-27 19:20:26
一台海信电视蓝灯亮不开机  打印信息发上来给大家看看是哪里坏了
 楼主| 发表于: 2017-3-1 12:20:16
COM4, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4, Printed by RT809H:
Nasa: BD_MST6180_64M_HISENSE
SPI BOOT
Console Initial OK
66
[123456789A][123456789A]
0055
BIST_0 PASS.
MIU Initial OK
Hello Nasa:A0000000
  _readonly_start=243000, _readonly_end=42F000
MIU protect align=1000
Beon protect start=243000, end=42F000
  heap => 5FCF40, => 640000
## heap size is 268K under 300K!!
@@@@@@ u32CpuSpeedMHz= 216 MHz
Hit = 0
wPM_WakeUpDevice 0x185
=> AC_BOOT (0)
PM Wakeup by 0x0
MDrv_Power_PMPowerRst() Line 132:
create Audio SHM data ...
USB_Init_Configure port 0
USB_Init_Configure port 0 done...
USB_Init_Configure port 1
USB_Init_Configure port 1 done...C悙   console_init() done
Flash is detected (0x0709, 0xEF, 0x40, 0x16)
MDrv_SERFLASH_Init() done
MApp_DB_Check()
MApp_DB_GEN_Init()
=> GoodUnit=0, WriteTime=1
msAPI_DB_GEN_Printf_Variable():
s_stDB_GEN_InitData:
u8FlashBank: 0x3E
.u16FlashSaveUnitSize: 4096
.u32DramDataAddr: 0x640000
.u16DramDataSize: 2872
u8FlashUnitNumPer1Bank=16
u8FlashUnitNumTotal=32
u16FlashUnitInfoOffset=0xFE0
MApp_DB_Factory_LoadSettingAndCheck()
MApp_DB_CH_Init()
msAPI_DB_CH_Printf_Variable():
s_stDB_CH_InitData:
u8FlashBankStart: 0x3C
.u8FlashSaveBankCount: 1
.u32DramDataAddr: 0x641000
.u32DramDataSize: 0xE2DC
u8FlashBankStart_0=0x3C
u8FlashBankStart_1=0x3D
u32CheckDataOffset=0xFFF0
MApp_DB_CH_LoadDataBase()
Warning: DB_CH_VER: Id is wrong! 0xFFFFFFFF, 0xA55A5679
Warning: DB_CH: DataBase version is wrong!
Error: Load DB_CH from flash failed
Keypad Initialize OK
= TCON_PNL_Nasa_Hisense_NewIPS32 =
MApi_XC_ChangePanleExtType(res=46)p./
MApi_XC_ChangePanleExtType, 6304, u16PanelLinkType =24
PANEL_DEFAULT_TYPE_SEL= 46
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
LINK TYPE = EXT
[_MDrv_PNL_Init_LPLL][304]pstPanelInitData->u16Width=1366, pstPanelInitData->u16Height=768
[_MDrv_PNL_Init_LPLL][306]u16HTotal=1560,u16VTotal=806,pstPanelInitData->u16HTotal=1560,pstPanelInitData->u16VTotal=806, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][349]pstPanelInitData->u16Width=1366, pstPanelInitData->u16Height=768
[_MDrv_PNL_Init_Output_Dclk][351]u16HTotal=1560,u16VTotal=806,pstPanelInitData->u16HTotal=1560,pstPanelInitData->u16VTotal=806, u16DefaultVFreq=600
_MApi_XC_Sys_Init_TCON_Panel(): eTCONPNL_TypeSel=12
MDrv_PNL_TCON_DumpGENRegTab
>> _MApi_XC_Sys_Init_TCON_GAMMA(0xE8)
GMA:[addr=0000, val=02]
GMA:[addr=0002, val=3F]
GMA:[addr=0003, val=33]
GMA:[addr=0004, val=7B]
GMA:[addr=0005, val=30]
GMA:[addr=0006, val=92]
GMA:[addr=0007, val=D3]
GMA:[addr=0008, val=2A]
GMA:[addr=0009, val=72]
GMA:[addr=000A, val=0D]
GMA:[addr=000B, val=21]
GMA:[addr=000C, val=01]
GMA:[addr=000D, val=78]
GMA:[addr=000E, val=14]
GMA:[addr=000F, val=A1]
GMA:[addr=0010, val=14]
GMA:[addr=0011, val=0A]
GMA:[addr=0012, val=20]
GMA:[addr=0013, val=2A]
GMA:[addr=0014, val=00]
GMA:[addr=0015, val=00]
GMA:[addr=0016, val=00]
GMA:[addr=0017, val=00]
GMA:[addr=0018, val=00]
GMA:[addr=0019, val=00]
GMA:[addr=001A, val=00]
GMA:[addr=001B, val=00]
GMA:[addr=001C, val=00]
GMA:[addr=001D, val=00]
GMA:[addr=001E, val=00]
GMA:[addr=001F, val=00]
GMA:[addr=0020, val=00]
GMA:[addr=0021, val=00]
GMA:[addr=0022, val=00]
GMA:[addr=0000, val=0A]
[addr=1030C2, msk=33, val=00]
[addr=1030C2, msk=08, val=00]
_MApi_XC_Sys_Init_TCON_Panel - end
[XC,Version] 00442327
MApi_XC_Init, 537, pXC_InitData->stPanelInfo.eLPLL_Type=24
** MHL Cbus index value 0
** MHL function support in port A
PACLK:0xC554
PACLK:0xC554
PACLK:0xC554
MHL Init, MHL_TYPE = 0x10
** Nasa Load MHL EDID...
** Nasa Load DevCap...
** MHL third DTD start at 9F in port A
** MHL total have 6 DTD in port A
** MHL get video data block length 12 in port A
** MHL get audio data block length 3 in port A
** MHL get speaker allocation data block length 3 in port A
** MHL get vender specific data block length 5 in port A
** MHL Cbus initial mux to port A
mapi_mhl_init()
[GOP_ALL, PID 0, TID 0x-1][Driver Version]: 0089, BuildNum: 0289, ChangeList: 2147483647
[HAL_TSP_CPU_SetBase][2167] load firmware (address, size) = (0x00601400, 0x00002A28)
firmware 111 0x00601400 0x00000000 0x0000C028
[HAL_DSCMB_SetBank][156] Set bank 0xA0200000
=== [Utopia Version] ===
[MSD6180][Hisense][CL817363] Utopia Version[21]
g_u8DCOnOff = ON
Mirror function (1)
u32ReadBuffVirAddr = 80E60000, u32IntBuffVirAddr = 80F60000, u32OutBuffVirAddr = 81B60000
verJPD_SetStatus >>>>>>>>>>> w:1365,  h:767,  p:1376
MApi_PNL_En,stGenSetting.g_SSCSetting.LVDSSwing = 110
[GOP0, PID 0, TID 0x-1][Driver Version]: 0089, BuildNum: 0289, ChangeList: 2147483647
Patch ReWrite Tcon regsiter,MApi_PNL_SetBackLight
0x1032DB = 0x15
0x1032DA = 0x95
0x1032DD = 0x0
0x1032DC = 0x0
@INTERN_DTMB_PAD_TS1_Enable...
 楼主| 发表于: 2017-3-1 12:27:09
flash 程序重写了再换了没用  1.15V 3.3V 1.8 5V都正常的 还是不开机
 楼主| 发表于: 2017-3-1 12:39:17
Error: Load DB_CH from flash failed   这个失败
发表于: 2018-7-9 12:46:48 来自手机
天书看不懂啊
来自: 微社区
GMT+8, 2026-4-9 16:16 , Processed in 0.054880 sec., 9 queries .
