查看: 3709|回复: 5
TOSHIBA Model: 26AV605PR
发表于: 2017-2-18 09:59:15
Plesk Panel: LTA260AP02 004
The CON-the T: 260AP02C2LV0.2, LMX6322T1, TPS65160A, AG32AE2, i7822, 416WP, 2042AF
Inverter (the backlight): SSI260_4UAO REV0.5
Inverter the PWM: SEM2006
Inverter the MOSFET: STV411D
The Supply the Power (the PSU): 715G3370-1 E250 7 75,015,110 PC BOARD ASSY, POWER, G3370- CXX-1-081219, ADTV82412AC7
The Power the PWM: A6069H
MAINBOARD: 715G3385-1 the E200 13 75015215 PC BOARD ASSY, MAIN, 26AV605PB, CBPFR3HBA2
MAINBOARD the IC: 24C32WP, the LF-MST9A885GL, HY5DU2B1622FTP-4
Tuner: TAFT-S710D
The Remote: the CT-90326
Brand: the SAMSUNG
the Model: LTA260AP02
the Type: a-the TFT-the LCD of Si, Plesk Panel
's Diagonal size bed: 26.0 inch
Resolution: 1366x768, a WXGA
the Display-Mode: APVA, of Black Normally, Transmissive
the Active Area: 575.769x323.712 mm
the Surface : Antiglare (Haze 14%), the Hard coating (3H)
the Brightness: 450 the cd / m2
the Contrast the Ratio: 4000: 1
Display Colors: 16.7M (8-bit), CIE1931 72%
the Response Time The: 8 (the G to the G)
the Frequency: 60Hz
the Lamp the Type: 4 Embedded the CCFL pcs (Inverter)
the Signal the Interface: the LVDS (1 ch, 8-bit), 30 pins
Voltage: 12.0V
发表于: 2017-2-20 19:20:56
谢谢你的分享
发表于: 2017-2-20 19:21:43
谢谢你的分享
发表于: 2017-2-20 19:22:19
谢谢你的分享
发表于: 2017-2-20 19:22:48
谢谢你的分享
发表于: 2017-2-20 19:23:31
谢谢你的分享
GMT+8, 2026-4-15 08:32 , Processed in 0.050796 sec., 9 queries .
