查看: 3862|回复: 4
康佳LED42MS11PD绿灯亮不开机检修一例
发表于: 2016-12-21 11:34:05
版号MST6M182 35015540 REV-00  屏LC42EUN(SD)(F1) 绿灯亮黑屏,本机键控和遥控均无效。检测各电压均正常。连接RT809F开机打印信息:
2016-12-7, 15:16:25
COM12, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
  SPI BOOT
Console Initial OK
Maria10: BD_MST006B_10AVS_10315
MIU: DDR2_800MHz
BIST_0 PASS.
55
0055
MIU Initial OK
重刷程序无果。疑N501至N502 DDR2数据传输电路有问题。经检测N501至N502之间的电阻排RA511的7-8脚开路,用一75Ω1/16W电阻直接焊在7-8脚。反复开关机和长时间开机,一切正常!修复后的开机打印信息如下:
2016-12-8, 12:18:42
  SPI BOOT
Console Initial OK
MIU: DDR2_800MHz
BIST_0 PASS.
55
[23456789AB][23456789AB]
0066
MIU Initial OK
sar input test...
=MApi_PNL_SetBackLight DISABLE=
==INV_CTL_Off==
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
=msAPI_GPIO_RegisterGPIOMethods=
GE_SetOnePixelMode
PM Wakeup by 0xFF
+++++++g_IPanel.Enable-off+++++++++= = 150
s8SN0(68) s8SN1(67)
g_u8DCOnOff = OFF
POWERON_MODE_SAVE >>
+++++++g_IPanel.Enable-on+++++++++= = 113
=MApi_PNL_SetBackLight ENABLE=
==INV_CTL_On==
g_u8TransientBacklight = 100
bPictrueTest == 0
22 msAPI_Logo_LoadJpeg failed
load co-processor code
$$$$chaneg source!
------KTV PreScale------
=0=SET AV AV OUT SEL=
[Photo tCropWin] x = 0, y = 0, w = 780, h = 438
[Photo tDstWin] x = 0, y = 0, w = 780, h = 438
sound test
stGenSetting.g_SoundSetting.Volume=93Disable Aeon
Disable Aeon Done
DSP code loaded successfully
#EnableEQ
----else----
$$$$chaneg source!
$$$$chaneg source!
after preinit----sentesu stGenSetting.g_SysSetting.fKeypad=0
========= CUS04_ATV_MM_M10 =========
DVB-T Software Version: 0.305665
[Board]: BD_MST6M182_KONKA_PR_3D
[Panel]: LG42_LC420EUNSDF1
[Tuner]: AFT7W006
[MEMORY_MAP]: MMAP_128MB
[DRAM SIZE]: 128 MB
[FLASH SIZE]: 4 MB
[ATV]: PAL
[Mirror]: 0
[ENABLE_PWS]: 0
[ENABLE_POWER_SAVING_DPMS]: 1
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]
[MWE]
[DISPLAY_LOGO]
******** VCap = 576, PreVtt = 625
发表于: 2016-12-21 13:07:09
好贴,感谢技术贴分享。
发表于: 2016-12-31 17:58:18
感谢楼主经验分享
发表于: 2016-12-31 23:36:56 来自手机
感谢楼主师傅分享的经验
发表于: 2017-1-1 00:06:45
多谢楼主分享
GMT+8, 2026-3-22 03:49 , Processed in 0.048899 sec., 10 queries .
