查看: 3099|回复: 2
求大家帮忙看下我这个打印信息
发表于: 2016-11-20 20:30:30
UART_115200
BIST0-OK
BIST1-OK
_U
Hello U-Boot
U-Boot 1.1.6 (Oct 11 2011 - 23:03:49)
Board: MSTAR AMBER1 (CPU Speed 576 MHz)
DRAM:  256 MBytes
U-Boot is running at DRAM 0x87600000
Module: KEYPAD USB FAT NAND FLASH UBI UBIFS NET SPI STANDBY JFFS2 LOGO OSD ENV=SERIAL
Flash is detected (0x0707, 0xEF, 0x40, 0x14)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 1048576
        u32SecNum      = 16
        u32SecSize     = 65536
>>> nand: AUTO CE/WP
Flash Make code = 0xEC, ID = 0xDC
NAND: 512 MBytes
In:    serial
Out:   serial
Err:   serial
Net:   MSVC00B000100100421604TH0000000T
EnvFlag =: 0x8BCECE5E.....CONFIG_ENV_ADDR=: 0xE0000
cbuffer[0] =:0xFF...cbuffer[1] =:0xFF...cbuffer[11] =:0xFF
Check USB port[0]:
Check USB port[1]:
keypad_pressed_1 is:0
[0]adc_val =:0xFF
keypad_pressed_2 is:0
--> ac boot <--
UART BUS OFF!
 楼主| 发表于: 2016-12-5 11:54:01
想请教是不是NAND故障,就有几行不对,我上块好板。
Flash is detected (0x0B01, 0xC8, 0x40, 0x14)
        u32AccessWidth = 1
        u32TotalSize   = 8388608
        u32SecNum      = 128
        u32SecSize     = 65536
GMT+8, 2026-3-22 05:20 , Processed in 0.044992 sec., 10 queries .
