查看: 10664|回复: 5
长虹39D2000N主板-ZLS53GI2电视开机重启求助
发表于: 2016-8-21 16:50:56
本机开机就重启,下面是打印信息,求助,用U盘强制升级U盘灯闪几下就没反应了,我刷的程序是ZLS53GI的,后面不带2,不知是不是一样用的,大师们帮看一下!
发表于: 2016-8-22 10:11:30
ZLS53GI和ZLS53GI2是不一样的,找对软件在升级就OK。
 楼主| 发表于: 2016-8-22 11:20:52
UART_115200
BIST0-OK
[123456789A][123456789AB][23456789AB][123456789AB]-5666
U[AT][MB][start ub][2818]
U-Boot 2011.06 (Feb 11 2015 - 08:23:42)
DRAM:  256 MiB
Hello U-Boot
Stack Pointer at: 87e45ac0
uboot held at [8f000000~90000000]
Now running in RAM - U-Boot at: 871f0180
NAND:  HAL_SPINAND_SetCKG() u8CkgSpi 104
128 MiB
*** Warning - set default for mtdparts, using default environment
Creating 1 MTD partitions on "nand0":
0x000000640000-0x000000840000 : "mtd=2"
Bad block table found at page 65216, version 0x01
Bad block table found at page 65152, version 0x01
nand_read_bbt: Bad block at 0x000006000000
nand_read_bbt: Bad block at 0x000007f80000
nand_read_bbt: Bad block at 0x000007fa0000
nand_read_bbt: Bad block at 0x000007fc0000
nand_read_bbt: Bad block at 0x000007fe0000
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size:   131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
Can't find "CTRL" partition
restore UBI scan
UBI: attached mtd1 to ubi0
UBI: MTD device name:            "mtd=2"
UBI: MTD device size:            2 MiB
UBI: number of good PEBs:        16
UBI: number of bad PEBs:         0
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    250
UBI: number of internal volumes: 1
UBI: number of user volumes:     1
UBI: available PEBs:             1
UBI: total number of reserved PEBs: 15
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 334/126
Volume  not found!
NAND read: device 0 offset 0x180000, size 0xa8
168 bytes read: OK
Volume "MPOOL" found at volume id 0
UART BUS OFF!!UART_115200
打印信息显示内存有坏块,这种情况影响吗?
发表于: 2017-10-5 08:19:14
换软件或U盘试试,不过,我修一台U升级两次,都一两个月又返修了!
发表于: 2017-12-15 16:36:26
师傅在吗请问电视修好了吗我也遇到和你一样的问题求此机数据
发表于: 2017-12-27 08:00:00
同求数据 给个 谢谢
GMT+8, 2026-2-3 22:46 , Processed in 0.053801 sec., 11 queries .
