RT809H使用教程--NAND闪存-K9F1G08U离线自动识别与读写--以创维42K08RD为例
发表于: 2020-4-1 09:22:22
网盘文件没有了,要不上传,要不删帖吧
发表于: 2020-5-29 15:17:12
there was a problem with writing NAND K9GAG08U0E writes incorrectly can there be a problem in the program settings? Samsung ue32d5500rw TV. Maybe someone faced a problem
写入NAND K9GAG08U0E写入有问题,程序设置是否有问题?三星ue32d5500rw电视。也许有人遇到问题
发表于: 2020-7-11 11:44:27
Да у меня такая же проблема с NAND K9GAG08U0E пишет  и читает некорректно после сравнения дампа получается много отличий но идеи для этой микросхемы нужен свой алгоритм большая просьба кто может написать утилиту для прошивки этих микросхем в дополнительное ПО.
是的,我对NAND K9GAG08U0E遇到同样的问题,比较转储后它的读写错误,有很多差异,但是该芯片有很多想法,我需要自己的算法,请谁编写一个实用程序将这些芯片刷新到其他软件中。Yes, I have the same problem with NAND K9GAG08U0E it writes and reads incorrectly after comparing the dump, there are many differences, but there are many ideas for this chip I need my own algorithm, please who can write a utility for flashing these chips into additional software
发表于: 2020-7-11 14:15:56
F59L1G81A 与 FAT32
大家好,我成功转储了我从USB闪存驱动器焊接的F59L1G81A。
我知道里面有FAT32文件系统。
您建议使用哪种软件提取其数据?
Hello everyone, I successfully dumped a F59L1G81A that I solder from an USB Flash Drive.
I know that has a FAT32 file system in it.
Which software do you recommend to extract its data?
发表于: 2020-8-21 19:47:06
thanks!!
te lo agradezco
发表于: 2025-11-4 13:02:03
NAND闪存 有坏块,设置里, 硬拷贝  跳过坏块重组数据   跳过坏块重建坏块表,选哪个?
发表于: 2026-1-16 14:36:51
nand  往里写数据选3个选项那个,硬拷贝   还是跳过坏块并重组数据   还是跳过坏块重建坏块表
GMT+8, 2026-4-22 21:04 , Processed in 0.051424 sec., 10 queries .
