查看: 2036|回复: 1
康佳LED42E510DE主芯片MSD6I982闪存W25Q80 在线数据 打印信息
发表于: 2016-4-14 12:43:15
康佳LED42E510DE主芯片MSD6I982闪存W25Q80.打印信息
COM5, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
UART_115200
BIST0-OK
[3456789AB]
[456789ABCD]-78
_U
Hello U-Boot
U-Boot 1.1.6 (Sep 15 2011 - 17:30:22)
Board: MSTAR AMBER1 (CPU Speed 576 MHz)
DRAM:  256 MBytes
U-Boot is running at DRAM 0x87600000
Module: KEYPAD USB FAT NAND FLASH UBI UBIFS NET SPI STANDBY JFFS2 LOGO OSD ENV=SERIAL
Flash is detected (0x0707, 0xEF, 0x40, 0x14)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 1048576
        u32SecNum      = 16
        u32SecSize     = 65536
>>> nand: AUTO CE/WP
Flash Make code = 0xEC, ID = 0xDA
NAND: 256 MBytes
In:    serial
Out:   serial
Err:   serial
Net:   MSVC00B000100100421604TH0000000T
EnvFlag =:22.....CONFIG_ENV_ADDR=:E0000
cbuffer[0] =:0xFF...cbuffer[1] =:0xFF...cbuffer[11] =:0xFF
Check USB port[0]:
Check USB port[1]:
keypad_pressed_1 is:0
[0]adc_val =:0xFF
keypad_pressed_2 is:0
--> ac boot <--
UART BUS OFF!
发表于: 2016-4-14 12:51:19
楼主辛苦了,
GMT+8, 2026-3-24 12:44 , Processed in 0.048032 sec., 10 queries .
