查看: 13725|回复: 11
海信LED37K11蓝灯亮不开机
发表于: 2015-3-14 22:18:43
测主板供电都正常,打印信息如下:
NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3,3V 8-bit)
Creating 5 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00020000 : "NPT"
mtd: Giving out device 0 to NPT
0x00020000-0x00120000 : "BL0"
mtd: Giving out device 1 to BL0
0x00120000-0x00220000 : "BL1"
mtd: Giving out device 2 to BL1
0x00220000-0x07460000 : "UBI"
mtd: Giving out device 3 to UBI
0x07460000-0x08000000 : "NA"
mtd: Giving out device 4 to NA
parse_cmdline_partitions: add_mtd_partitions
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
UBIFS error (pid 1): ubifs_recover_leb: corrupt empty space LEB 46:20480, corruption starts at 3868
UBIFS error (pid 1): ubifs_scanned_corruption: corruption at LEB 46:3868
UBIFS error (pid 1): ubifs_recover_leb: LEB 46 scanning failed
VFS: Cannot open root device "ubi:RFS" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00             128 mtdblock0 (driver?)
1f01            1024 mtdblock1 (driver?)
1f02            1024 mtdblock2 (driver?)
1f03          116992 mtdblock3 (driver?)
1f04           11904 mtdblock4 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
请帮高手分析一下是哪故障
发表于: 2015-3-15 21:01:18
用什么设备测的,这么多看不懂的,RT809吗?
发表于: 2015-3-15 21:28:22
是使用RT809F开机打印功能。
发表于: 2015-3-18 07:09:26
如果5VS,5VM,12V,都正常,测一下SW和PWM,如果有电压就是电源板的问题,检查一下大滤波电容电压是不是在390V以上,有一个没有电压的话就是主板上的故障,多数是FLASH坏了,
 楼主| 发表于: 2015-3-20 18:25:19
用网线升级不成功,现在编程器也连接不上,怎办?
 楼主| 发表于: 2015-3-21 14:26:49
把mboot3脚对地短路,然后开机,再连机能正常打印,可能是nand flash块坏以待求证
 楼主| 发表于: 2015-3-31 13:41:22
是主程序坏,用网线升级成功
 楼主| 发表于: 2015-3-31 13:45:13
LED37K11正常的打印信息
发表于: 2015-4-9 20:12:04
发表于: 2016-5-26 16:42:56
dylaj123 发表于 2015-3-31 13:41
是主程序坏,用网线升级成功
你好,能把主程序发一份吗?谢谢啊。
GMT+8, 2026-4-9 21:17 , Processed in 0.065260 sec., 10 queries .
