查看: 3414|回复: 2
LED46IS95D(3BOM、MSD6I981平台) 黑屏
发表于: 2014-4-3 21:54:12
LED46IS95D3BOMMSD6I981平台) 黑屏      作者:徐磊胜
   一台LED46IS95D(3BOM)机器,开机声音正常,背光亮无显示故障。检测主芯片N501各组供电均正常(如果内部LVDS发送器供电丢失会出现此故障),MEMC芯片(MST6M30QS)的供电、晶振、复位正常。代换MEMC芯片外挂FLASH(W25X40A)、升级N501(MSD6I981)外挂主程序均未排除故障。查看打印信息和正常的相同。考虑此机型N501假焊的较多,故补焊N501,试机故障排除。(其它机型无图故障多为MEMC部分电路异常,此系列机型多为N501假焊)
发表于: 2017-1-8 22:17:49
谢谢了看看了
发表于: 2017-4-1 12:08:55
康佳LED42IS95D黑屏 , 以下是打印信息。我不会看是否正常,  有会的大师指点以下  。
2017-4-1, 9:57:44
COM5, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
UART_115200
BIST0-OK
[3456789A]
[456789ABC]-68
_U
Hello U-Boot
U-Boot 1.1.6 (Sep 14 2011 - 02:52:20)
Board: MSTAR AMBER1 (CPU Speed 576 MHz)
DRAM:  256 MBytes
U-Boot is running at DRAM 0x87600000
Module: KEYPAD USB FAT NAND FLASH UBI UBIFS NET SPI STANDBY JFFS2 LOGO OSD ENV=SERIAL
Flash is detected (0x0707, 0xEF, 0x40, 0x14)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 1048576
        u32SecNum      = 16
        u32SecSize     = 65536
>>> nand: AUTO CE/WP
Flash Make code = 0xEC, ID = 0xDA
NAND: 256 MBytes
In:    serial
Out:   serial
Err:   serial
Net:   MSVC00B000100100421604TH0000000T
EnvFlag =:108.....CONFIG_ENV_ADDR=:E0000
cbuffer[0] =:0xFF...cbuffer[1] =:0xFF...cbuffer[11] =:0xFF
Check USB port[0]:
Check USB port[1]:
keypad_pressed_1 is:0
[0]adc_val =:0xFF
keypad_pressed_2 is:0
--> ac boot <--
UART BUS OFF!
GMT+8, 2026-3-21 21:27 , Processed in 0.046794 sec., 10 queries .
