查看: 316|回复: 3
We request support assistance in resolving the connection issue.
发表于: 2026-3-16 23:11:57
Edited by rtyuiop at 2026-3-16 17:13
The problem arises spontaneously;
there is a lack of connection between the program and the programmer,
and the light bulb is flickering with red and green flashes.
Using JTAG compatibility mode, the device manager installs the emulator driver, and then the programmer USB firmware is repaired.  发表于 2026-3-17 08:57
 楼主| 发表于: 2026-3-17 22:38:40
Edited by rtyuiop at 2026-3-17 16:42
The fault was identified as a change in this component from another programmer. How can it be repaired and reprogrammed, and how can a copy be sent?
Install the emulator driver manually, and then the USB is estimated to be fixed. Here are the detailed steps.https://mp.weixin.qq.com/s/XiWgc4Vf6ixUwyg4nAflmA  发表于 2026-3-19 09:00
GMT+8, 2026-9-18 11:13 , Processed in 0.055439 sec., 17 queries .
