查看: 345|回复: 0
MSD6A938方案打印信息跑到”EFI services will not be available.“不开机,哪位老师能指导一下 谢谢
发表于: 2025-10-13 09:54:57
当贝投影板子MSD6A938vpn,EMMC镁光64G,待机正常,按开机后就跑到”EFI services will not be available.“,能进后台CU升级,升级完也这样,不知道什么原因,有老师能指点指点吗?AC_ON
MIU0_DQS-OK
MIU1_DQS-OK
MIU2_DQS-OK
BIST0-OK
BIST1-OK
BIST2-OK
#_U
Relocation Offset is: 01800000
[AT][MB][start ub][1288]
U-Boot 2011.06-01068-g382cd8b-dirty (Jan 03 2023 - 15:18:23)
msIR_Initialize
[Utopia][SYS]: Function = SYSOpen, Line = 1115, current resource pri_shm content is: 0
[Utopia][SYS]: Function = SYSOpen, Line = 1134, [SYS INFO] OPEN INSTANCE...
create instance at 31B6F830 with private size 128 bytes at 31B6F880
[Utopia][MIU]:
[MIU INFO] miu opencreate instance at 31B6F908 with private size 100 bytes at 31B6F958
create instance at 31B6F9C0 with private size 56 bytes at 31B6FA10
uboot held at [317DDF60~33300000],size=01B220A0
DRAM:  307 MiB
Now running in RAM - U-Boot at: 32800000
eMMC: HS400 200MHz
eMMC 58.24 GB [747BFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MAC:  0x4C: 0x91: 0x7A: 0xB5:0xD9: 0x41
Init PWM0Init PWM1Init PWM2Init PWM3[Utopia][CPU]:
[CPU INFO] cpu opencreate instance at 31B7FEB8 with private size 44 bytes at 31B7FF08
[Utopia][CPU]: CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[tu]: €2?€2?€2 €2`€2?€2xV4
[AT][MBoot][Driver Init][1413]
gpio[155] is 0
gpio[156] is 0
gpio[157] is 0
gpio[158] is 0
###dangs firston
Saving Environment to MMC...
Writing to MMC(0)... 128 blocks written: OK
done
[Utopia][MIU]: Ioctl MDrv_CMD_MIU_Dram_Size failMPOOL size : 0x200000
create instance at 31B90E40 with private size 324 bytes at 31B90E90
create instance at 31B90FD8 with private size 324 bytes at 31B91028
create instance at 31B91170 with private size 324 bytes at 31B911C0
create instance at 31B91308 with private size 324 bytes at 31B91358
Changelist:     24543697
WDT is not Enable !!!setenv WDT_ENABLE 1 to enable it.
factory_poweron_mode:secondary
isPowerOn:
mmc change mount : tvcustomer
** File not found /Customer/reboot_flag
fore uup IRKey [0xFF]
DC on !!
!!! [do_audiopreinit]  Skip Power Music  !!!
bbb>>> do_bt_usb_toggle_reset end BALL_AA5 = 10
create instance at 31B90DF0 with private size 352 bytes at 31B94B58
MsDrv_PNL_Init:Bypass SetDivison
MDrv_PNL_Init u32PnlRiuBaseAddr = tx
MDrv_PNL_Init u32PMRiuBaseAddr = tx
[_MDrv_PNL_Init_LPLL][393]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][395]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][445]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][447]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[MApi_XC_MLG_GetStatus, 2664]No instance existed, please get an instance by calling MApi_XC_Init() first
gpio[205] is 0
reset c788 rst
gpio[205] is 1
gpio[176] is 0
wakeupsource :5
set bppwm period : 0x4B0, duty 0x43B
done
F1 dang set blue led off
[AT][MB][panel_pre_init][2794]
Wait for PM51 standby DRAM ...........PM51 run ok...........
[AT][MB][bootlogo begin][2802]
create instance at 31B914A0 with private size 312 bytes at 31B914F0
[AT][MB][JPD Decode][2841]
[UTOPIA INFO] close moduleNames[tu]: 2`€2?€2?€2 €2`€2?€2xV4
done
done
[showLogo] GOP Boot Logo Index 3
create instance at 31B924E0 with private size 1720 bytes at 31B92530
[Utopia][GE HAL]: GE_EnableDynaClkGate
create instance at 31B92BF0 with private size 12229 bytes at 31BA56F0
create instance at 31BA86C0 with private size 1888 bytes at 31BA8710
[Utopia][GOP DRV]:
Not support GOP_3 palette!'
[Utopia][GOP HAL]: [_SetDualOpMux]GOP3 can't set to other mode when GOP0 is on 4K@120
[Utopia][GOP HAL]: [_SetDualOpMux]GOP1 can't set to other mode when GOP2 is on 4K@120
[AT][MB][Show Logo][2952]
create instance at 31BA8F78 with private size 324 bytes at 31BA8FC8
create instance at 31B92C40 with private size 324 bytes at 31B92C90
create instance at 31B92DD8 with private size 324 bytes at 31B92E28
create instance at 31B92FA8 with private size 324 bytes at 31B92FF8
R2 Boot from 0x2F1C0000
[Utopia][CPU]:
[CPU INFO] cpu opencreate instance at 31B803C0 with private size 44 bytes at 31B92F70
create instance at 31B80410 with private size 324 bytes at 31B80460
create instance at 31B805A8 with private size 324 bytes at 31B805F8
create instance at 31B80740 with private size 324 bytes at 31B80790
!!! [do_bootmusic]  Skip Power Music  !!!
[AT][MBoot][Boot Nuttx][3695]
## Booting kernel from Legacy Image at 25000000 ...
   Image Name:   MStar-linux
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    19906228 Bytes = 19 MiB
   Load Address: 20280000
   Entry Point:  20280000
   Contents:
      Image 0: 14268512 Bytes = 13.6 MiB
      Image 1: 5637704 Bytes = 5.4 MiB
## Loading init Ramdisk from multi component Legacy Image at 25000000 ...
ramdisk start = 0x25D9B8AC, ramdisk end = 0x262FBEF4
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
-usb_stop(USB_PORT3)
-usb_stop(USB_PORT4)
   Loading Multi-File Image ... OK
done
[AT][MB][start kr][3782]
Starting kernel ...
set 64 bit mode
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.86 (user@dbbuild-216) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG MStar-1.13.1-4.9-2015.04 - MStar GCC 4.9-2015.04) ) #1 SMP PREEMPT Tue Jan 3 15:19:32 CST 2023
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] __fdt_pointer = 0x23000000
[    0.000000] Looking for initrd properties... __ramdisk_start = 0x25d9b8ac, __ramdisk_end = 0x262fbef4
[    0.000000] Function = early_init_dt_check_for_initrd, Line = 615, PHYS_OFFSET is 0x20200000, PAGE_OFFSET is 0xFFFFFFC000000000
[    0.000000] initrd_start = 0xffffffc005b9b8ac, initrd_end = 0xffffffc0060fbef4
[    0.000000] Function = early_init_dt_check_for_initrd, Line = 629, no "linux,initrd-start" setting @dts
[    0.000000] !!!!!!!!!!!!!!!!!!!!!! coredump_path is:/data/core_dump.%%p.gz
[    0.000000] SD_CONFIG_NUM = 3
[    0.000000] MSTAR_MIU2_BUS_BASE 0x0000000300000000
[    0.000000]
[    0.000000] LX_MEM  = 0x20200000, 0x23F00000
[    0.000000] LX_MEM2 = 0x50800000, 0x4F800000
[    0.000000] LX_MEM3 = 0xABC00000, 0x34400000
[    0.000000] LX_MEM4 = 0x300000000, 0x40000000
[    0.000000] EMAC_LEN= 0x100000
[    0.000000] DRAM_LEN= 0x0
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] Function = arm64_memblock_init, Line = 233, find cma_default buffer at only LX0
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 16 MiB at 43000000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 156 MiB for mstar_driver(OTHERS, pool_id is 23)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 156 MiB at 31000000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 248 MiB for mstar_driver(VDEC1, pool_id is 19)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 248 MiB at 50800000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 60 MiB for mstar_driver(OTHERS2, pool_id is 24)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 60 MiB at abc00000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 104 MiB for mstar_driver(VDEC0, pool_id is 20)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 104 MiB at af800000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 120 MiB for mstar_driver(MALI_GOP, pool_id is 18)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 120 MiB at b6000000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 240 MiB for mstar_driver(OTHERS3, pool_id is 25)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 240 MiB at 300000000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 96 MiB for mstar_driver(XC0, pool_id is 22)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 96 MiB at 30f000000
[    0.000000] PERCPU: Embedded 11 pages/cpu @ffffffc0e7b8a000 s16000 r8192 d20864 u45056
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 936017
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 575MB 1272MB 836MB 1024MB = 3707MB total
[    0.000000] Memory: 2632008k/2632008k available, 1163960k reserved
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
[    0.000000]     vmemmap : 0xffffffbc00707000 - 0xffffffbc0b600000   (   174 MB)
[    0.000000]     modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0e7c00000   (  3708 MB)
[    0.000000]       .init : 0xffffffc000c67000 - 0xffffffc000cf2e80   (   560 kB)
[    0.000000]       .text : 0xffffffc000080000 - 0xffffffc000c66fa4   ( 12188 kB)
[    0.000000]       .data : 0xffffffc000cf3000 - 0xffffffc000e1b860   (  1187 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:384
[    0.000000] Function = clocksource_of_init, doing arm,armv8-timer
[    0.000000] Function = arch_timer_init, arch_timer_rate is 12000000
[    0.000000] Architected cp15 timer(s) running at 12.00MHz (phys).
[    0.000000] sched_clock: 64 bits at 250 Hz, resolution 4000000ns, wraps every 8589934592000000ns
[    0.000000] [AT][KR][reset timer][4127]
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [ttyS0] enabled
[    0.000000] Function = start_kernel, ready to count printk time
[    0.192000] Calibrating delay loop (skipped), value calculated using timer frequency.. 24.00 BogoMIPS (lpj=48000)
[    0.196000] pid_max: default: 32768 minimum: 301
[    0.200000] thread_info_cache_init, alloc 1536 thread_pool
[    0.204000] Security Framework initialized
[    0.208000] Mount-cache hash table entries: 256
[    0.212000] Initializing cgroup subsys debug
[    0.216000] Initializing cgroup subsys freezer
[    0.220000] /cpus/cpu@0: Missing clock-frequency property
[    0.224000] /cpus/cpu@100: Missing clock-frequency property
[    0.228000] /cpus/cpu@101: Missing clock-frequency property
[    0.232000] /cpus/cpu@1: Missing clock-frequency property
[    0.236000] Function = mstar_smp_spin_table_prepare_cpu, Line = 101, for cpu 1
[    0.240000] Function = mstar_smp_spin_table_prepare_cpu, Line = 105, write to 0x100510
[    0.244000] Function = mstar_smp_spin_table_prepare_cpu, Line = 101, for cpu 2
[    0.248000] Function = mstar_smp_spin_table_prepare_cpu, Line = 105, write to 0x100510
[    0.252000] Function = mstar_smp_spin_table_prepare_cpu, Line = 101, for cpu 3
[    0.256000] Function = mstar_smp_spin_table_prepare_cpu, Line = 105, write to 0x100510
[    0.260000] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[    0.264000] EFI services will not be available.
GMT+8, 2026-3-18 08:58 , Processed in 0.062010 sec., 11 queries .
