查看: 1081|回复: 6
打印信息求助
发表于: 2025-6-26 15:39:04
海信H55A55蓝灯亮不开机,测电压都正常,打印信息如下,请高手帮忙看看是怎么回事
UART_115200
AC_ON
MIU0_DQS-OK
BIST0-OK
BIST1-OK
#_m
AUTH_KEYBANK_FAI
Relocation Offset is: 01700000
hs>>power-on
[AT][MB][start ub][477]
U-Boot 2011.06-00584-ga763002-dirty (Feb 10 2020 - 11:36:36)
msIR_Initialize
Function = SYSOpen, Line = 1071, current resource pri_shm content is: 0
Function = SYSOpen, Line = 1090, [SYS INFO] OPEN INSTANCE...
create instance at 2B4F3C50 with private size 128 bytes at 2B4F3C98
[MIU INFO] miu opencreate instance at 2B4F3D20 with private size 80 bytes at 2B4F3D68
create instance at 2B4F3DC0 with private size 52 bytes at 2B4F3E08
create instance at 2B4F3E40 with private size 52 bytes at 2B4F3E88
uboot held at [2B2DDF60~2C500000],size=012220A0
CPU  : << MStar >>#
Board: BD_MST123B_10A_MOONEY
DRAM:  197 MiB
Now running in RAM - U-Boot at: 2BB00000
eMMC: HS200 200MHz
eMMC 7.28 GB [E8FFF8h]
eMMC SLC mmc type undifined
eMMC MLC mmc type undifined
eMMC pre_eol_info undifined
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
no eeprom
0x8 0xBA 0x5F 0xC8 0xDD 0xC7
MACaddr = 0x80xBA0x5F0xC80xDD0xC7
the same ethaddr!
MAC:  0x8: 0xBA: 0x5F: 0xC8:0xDD: 0xC7
[CPU INFO] cpu opencreate instance at 2B5042F8 with private size 44 bytes at 2B504340
[UTOPIA INFO] close moduleNames[tu]: ????? ?`???xV4
[AT][MBoot][Driver Init][616]
[ERROR] Secure_doAuthentication:92: Error: Authentication Fail!!
[ERROR] Secure_doAuthentication:93:  Image address=0x3FB00110
[ERROR] Secure_doAuthentication:94:  RSA encryption's result=
[DUMP] Secure_doAuthentication:95:
2B2DCC40: 8C 92 F3 40 F0 32 3C 73 23 73 5F 15 1C 4A 47 CD    ...@.2<s#s_..JG.
2B2DCC50: 06 1E FE 2E 98 09 CD A4 ED 53 70 26 B3 20 A9 4C    .........Sp&. .L
[ERROR] Secure_doAuthentication:96:  Image's SHA result=
[DUMP] Secure_doAuthentication:97:
2B2DD040: 32 EE D9 4A 17 74 28 0E 8F 78 AC 49 70 B2 3E F4    2..J.t(..x.Ip.>.
2B2DD050: 7A 43 1E CD FB 16 AF 69 EB 6D E0 CC C0 56 A9 EB    zC.....i.m...V..
[ERROR] isCustomerKeyBankValid:1034:  Auth CustomerKeyBank FAIL
[ERROR] isCustomerKeyBankValid:1035:  RSA image public-N key=
[DUMP] isCustomerKeyBankValid:1036:
2B2DD08C: AA 5E 3F DA D0 1D DF 4A FA FE 67 A1 B5 3B BB 8B    .^?....J..g..;..
2B2DD09C: 93 1F EC BA AC 0F 0C 0E D6 1A 66 EC 04 C4 16 E5    ..........f.....
2B2DD0AC: A4 A6 9A AF EF B6 EE 7D A3 E7 A5 59 E4 00 6B C5    .......}...Y..k.
2B2DD0BC: FC E9 79 B2 8B 8E 81 13 6C 8A B6 CC 11 D9 A7 CE    ..y.....l.......
2B2DD0CC: A8 3C 7A 43 18 35 D0 4D A6 AE 40 CD 4D 04 14 F6    .<zC.5.M..@.M...
2B2DD0DC: CA 3D 5E F2 27 4E F3 8C 8A 6F BC 6A C4 CC D1 23    .=^.'N...o.j...#
2B2DD0EC: FB CA 63 8A BB C4 05 14 A9 98 12 76 71 F3 A3 6E    ..c........vq..n
2B2DD0FC: A8 B2 07 E4 0E 16 9B F7 5E C4 19 15 BE 3A 9E F2    ........^....:..
2B2DD10C: 30 9A 76 61 68 11 91 D6 AC 2C 22 AA 46 19 4D E8    0.vah....,".F.M.
2B2DD11C: C7 12 B7 EF CE 29 D3 8B B9 20 95 5C 0E 5A 26 FC    .....)... .\.Z&.
2B2DD12C: F9 65 1F 56 8F 3C DB 60 85 36 4A 2A 35 7D 94 BD    .e.V.<.`.6J*5}..
2B2DD13C: CF D0 CF 6C 61 50 64 B1 2A 9A 7D A2 AC 03 EC 25    ...laPd.*.}....%
2B2DD14C: 48 99 E0 13 B4 86 4E 68 15 65 32 06 82 3F 02 BE    H.....Nh.e2..?..
2B2DD15C: 4C 0D 59 4B 4C F6 54 82 38 AA 09 47 A3 1A 8B A1    L.YKL.T.8..G....
2B2DD16C: D1 F8 CC 09 11 15 8F FD 4C 01 46 0C 6F F7 8D B8    ........L.F.o...
2B2DD17C: 22 E4 87 28 51 F6 C0 09 7C EA D1 5C 46 B4 FB 4B    "..(Q...|..\F..K
[ERROR] isCustomerKeyBankValid:1037:  RSA image public-E key=
[DUMP] isCustomerKeyBankValid:1038:
2B2DD18C: 00 01 00 01    ....
[ERROR] isCustomerKeyBankValid:1039:  CustomerKeyBank signature=
[DUMP] isCustomerKeyBankValid:1040:
3FB00010: B8 8F 55 CE 3F 05 6A C0 01 FF 50 C9 31 4A 40 65    ..U.?.j...P.1J@e
3FB00020: 91 F2 31 75 56 76 B7 3F 4C 66 F0 18 6B AF 0D DC    ..1uVv.?Lf..k...
3FB00030: CD 59 C7 AE 7E AC 2E 34 4F 1D 89 42 41 D0 DB 85    .Y..~..4O..BA...
3FB00040: C8 37 7E 29 14 EE 65 62 96 8A 5B E7 1E F5 4B 45    .7~)..eb..[...KE
3FB00050: AC D0 23 22 F9 78 72 76 55 4A 03 CC 17 51 99 73    ..#".xrvUJ...Q.s
3FB00060: B8 C9 72 A2 15 D3 4A 10 5C 5B FB 3B 48 AD 3B 26    ..r...J.\[.;H.;&
3FB00070: 1E 2D 71 C5 15 C4 0F 64 9E C3 7E 93 19 89 30 AF    .-q....d..~...0.
3FB00080: 50 9D AE 95 09 38 19 2E CA D7 74 AC 9C 51 AC 50    P....8....t..Q.P
3FB00090: CF 9C 27 D2 0E 97 C7 FA D5 B4 A1 04 EC 97 BE 0C    ..'.............
3FB000A0: 91 73 38 EF 32 D0 AA 26 F9 DE 4E 18 8E 63 50 63    .s8.2..&..N..cPc
3FB000B0: FB DD 50 40 9E FF 20 CA E1 CC 41 61 19 CC 27 F6    ..P@.. ...Aa..'.
3FB000C0: 73 A1 77 DC 0D 3A 9B 82 E0 DD 52 89 27 BB F8 76    s.w..:....R.'..v
3FB000D0: 67 2D BE AD E3 80 D4 3D DF 5A 9C CA 30 4B 69 A1    g-.....=.Z..0Ki.
3FB000E0: 0F 99 A9 14 6B 4A 27 DB 14 D6 43 23 D0 B4 BE C8    ....kJ'...C#....
3FB000F0: A7 7A 40 FB 3D 15 48 37 35 93 34 93 28 58 60 A8    .z@.=.H75.4.(X`.
3FB00100: AD 8E 49 F3 34 C7 9A 84 C4 7F 03 1D 4D BC 40 3D    ..I.4.......M.@=
[ERROR] isCustomerKeyBankValid:1041:  clear CustomerKeyBank image=
[DUMP] isCustomerKeyBankValid:1042:
3FB00110: 5A E0 F7 57 EF A0 4B DD E0 ED 54 F2 0F B7 A8 FA    Z..W..K...T.....
3FB00120: 85 61 C1 B4 38 E2 D7 0A CD BB 9E 8B 8B 52 DA 3A    .a..8........R.:
3FB00130: 7E 22 76 D7 EA 43 D3 BF 28 87 03 BA 17 66 E0 63    ~"v..C..(....f.c
3FB00140: DA 89 89 44 4C CD D7 C9 4E 2E E2 76 05 D1 54 D6    ...DL...N..v..T.
3FB00150: A8 CE F0 FB 9C A3 46 5D C8 E4 BE D7 75 C7 5E 05    ......F]....u.^.
3FB00160: 54 A0 AF 99 DA 19 E8 EA C5 CA 17 4B 80 4C 6B 69    T..........K.Lki
3FB00170: B7 D8 21 93 59 E5 EB 74 E2 CE 44 15 DA A1 06 BA    ..!.Y..t..D.....
3FB00180: 39 F1 65 13 0B 36 B0 00 57 5A 25 87 F7 0A 46 39    9.e..6..WZ%...F9
3FB00190: 97 B7 02 D8 01 1D D0 4D 67 F1 7F E2 3B 5B 95 A7    .......Mg...;[..
3FB001A0: 3F 50 7A 23 5F 6C C8 61 EF E2 0F 40 C2 7C 9B 66    ?Pz#_l.a...@.|.f
3FB001B0: 0B C8 03 D8 54 FC 95 0D 5D 56 AC 13 A4 A9 C2 14    ....T...]V......
3FB001C0: 1A C7 FE EC 7D 54 A1 EC 83 2C 1F 76 48 DF 25 C9    ....}T...,.vH.%.
3FB001D0: 02 7D BA 4A 5D 4E E2 70 13 A6 1A 2A 62 7E 62 F6    .}.J]N.p...*b~b.
3FB001E0: BE 6E 54 06 71 C9 CD 79 70 77 A9 58 D7 82 02 94    .nT.q..ypw.X....
3FB001F0: 30 0C 5E 94 53 A8 45 BF C3 15 6C 27 71 D5 0E 99    0.^.S.E...l'q...
3FB00200: 90 B4 F3 71 D7 F9 13 F3 69 DB F0 35 16 F2 9F CA    ...q....i..5....
3FB00210: E3 26 64 A5 B4 93 8F 23 DA 3A 2F 3B 83 44 A3 06    .&d....#.:/;.D..
3FB00220: 54 56 D7 91 C8 B3 F7 A0 B5 8D 53 01 E8 BC F8 AF    TV........S.....
3FB00230: CD 31 B5 6B 69 54 7B 7E A0 DD 50 C9 B8 ED 92 EC    .1.kiT{~..P.....
3FB00240: E8 2E F8 AD 16 29 C0 56 CE 00 85 0F 3D 82 50 7A    .....).V....=.Pz
3FB00250: F8 A9 18 1B 1D F4 F1 85 1A 94 E9 B3 1E 16 BA 9D    ................
3FB00260: BF C0 DF C4 BD 16 FE 6A B0 2F 36 AD FB 1F 7B 69    .......j./6...{i
3FB00270: 8B 5B FC 64 4A 07 DD 5F EE 0E A8 50 36 AD 55 4C    .[.dJ.._...P6.UL
3FB00280: F2 78 F1 15 F6 C1 29 54 07 8E A1 4C 3A 08 65 19    .x....)T...L:.e.
3FB00290: 67 A9 35 EF DA 43 C6 57 5B F7 1A A0 4C E3 DE 1D    g.5..C.W[...L...
3FB002A0: 0B D1 55 30 EA B6 93 24 FE 1E 85 39 B4 B2 28 8E    ..U0...$...9..(.
3FB002B0: 28 81 36 85 08 CE 4B 19 DF 6D 64 9A 5D 69 6F C6    (.6...K..md.]io.
3FB002C0: 16 DE 98 A4 5C 71 03 C3 72 D0 76 28 78 5B F5 FF    ....\q..r.v(x[..
3FB002D0: C9 84 A1 DE FA BB A0 7A 0A 53 C0 57 F6 87 81 67    .......z.S.W...g
3FB002E0: D9 3A C0 54 5B 32 FC 4F BD E9 64 31 DA 88 41 40    .:.T[2.O..d1..A@
3FB002F0: 32 A6 41 53 AC E1 BF 0C ED 22 1E 74 6D 21 A9 17    2.AS.....".tm!..
3FB00300: 1F 0E 09 A6 0B 02 48 D2 47 BD F4 2A 2C 1C D1 F4    ......H.G..*,...
3FB00310: 23 30 24 E0 51 BE 83 E8 0A 53 59 49 2B 86 CE 38    #0$.Q....SYI+..8
3FB00320: A6 7F 57 07 3F 78 9F D9 40 92 FA F6 29 51 AF E2    ..W.?x..@...)Q..
3FB00330: FD A5 BD 6F 4E DF 7B 27 55 3B 42 56 02 7C 26 30    ...oN.{'U;BV.|&0
3FB00340: B8 6B F2 9B E3 65 5B D7 E7 90 2E C1 CD 1D 34 5D    .k...e[.......4]
3FB00350: 45 F5 60 0E 2B 02 01 B9 09 18 90 B6 97 C0 1A 49    E.`.+..........I
3FB00360: 5C E2 71 98 66 B4 D6 37 28 CA 57 04 2D A3 74 40    \.q.f..7(.W.-.t@
3FB00370: 0D 30 04 AB A9 72 B6 79 16 EB B3 BB EE 0C C1 A5    .0...r.y........
3FB00380: C6 26 15 85 9A 0A E5 61 12 70 4E EE 7A 60 6E F6    .&.....a.pN.z`n.
3FB00390: 4F 4E 14 5E 4E BB 5D D0 C4 81 76 D1 B8 7A C5 3F    ON.^N.]...v..z.?
3FB003A0: F7 93 E2 18 14 A1 D8 36 35 FD A4 56 FD EC 2D F5    .......65..V..-.
3FB003B0: 3E E6 23 AF 05 E8 C3 3E 1B 53 1E F1 7F 83 06 E8    >.#....>.S......
3FB003C0: FD 27 2D AA 60 1D 0D F9 BD C8 9C 0A E8 6E 70 24    .'-.`........np$
3FB003D0: A4 DC 40 39 1D 07 AF A0 8F 67 03 0E 88 8D 75 5C    ..@9.....g....u\
3FB003E0: 36 4E 1B BF D1 92 37 0B AD 85 7C C1 90 C7 A2 3E    6N....7...|....>
3FB003F0: 94 3A ED 54 8D 82 8D 46 6E 76 7F 26 AC 83 F7 76    .:.T...Fnv.&...v
3FB00400: D5 8A D9 EC 91 7D 1E 4A 3A 65 04 2D 25 61 21 D5    .....}.J:e.-%a!.
3FB00410: 33 E5 ED DC 8C 60 9A 6E A2 7F 98 E3 1D 62 62 80    3....`.n.....bb.
3FB00420: 8C 50 0C 0E A5 A6 33 20 2C C2 A4 AF B5 AB 79 7C    .P....3 ,.....y|
3FB00430: 0E 2C 7E B0 60 2E 0E B4 AA E5 83 50 08 78 BE 40    .,~.`......P.x.@
3FB00440: AF 06 09 B3 DB 7F F1 A7 ED 6E 23 37 71 C1 21 74    .........n#7q.!t
WDT is not Enable !!!setenv WDT_ENABLE 1 to enable it.
jump_to_console start!!
<< MStar >># UART_115200
发表于: 2025-6-27 08:52:55
按回车键上电能进控制台的话输入cu升级一下主程序试试
发表于: 2025-6-26 18:14:54
疑问,不开机怎么会有打印信息出来
 楼主| 发表于: 2025-6-26 19:50:52
蓝灯亮,按开机键没有任何反应,连接809H有打印信息
发表于: 2025-6-27 10:31:17
jump_to_console start!!  看看这是啥意思
发表于: 2025-6-27 16:38:04
出现这种打印信息是有由两种情况引起的,一是数据部分损坏,二是更换EMMC时写入了其他机型备份引起的,原因都是软件效验没有通过。这里的关键词是“AUTH_KEYBANK_FAI”,而不是其它的。另外,需要提醒大家,我们所看到的打印信息并不能用于判断故障,它仅是一个系统流程的监控。真正能用于判断故障的是要查看分析系统日志文件。因为现在智能机用的都是定制的linux系统,因此在维修中要想真真的看懂打印信息,就需要有计算机系统基础和软件编程基础,而是不是用百度翻译去翻译出一堆莫名其妙的计算机名词和术语。
 楼主| 发表于: 2025-6-28 14:15:18
谢谢各位老师的回复,此机已修好,是数据的问题
GMT+8, 2026-3-19 20:58 , Processed in 0.049262 sec., 12 queries .
