查看: 2548|回复: 12
【已修复,感谢大佬 】小米3分体式主机,emmc坏,更换emmc量产后,不开机,打印信息如下
发表于: 2025-6-22 11:47:47
[AT][MB][start do_reset]
do_reset: Using RIU_MAP: 0x1f000000, at 55
UART_115200
AC_ON
MIU0_DQS-OK
MIU1_MIST0-OK
BIST1-OK
BIST2-OK
_U
Relocation Offset is: 01100000
[AT][MB][start ub][334]
U-Boot 2011.06-00000-g74b24b3 (Jun 09 2017 - 09:11:24)
create instance at 57c75020 with private size 52 bytes at 57c75068
uboot held at [578ddf60~59300000],size=01a220a0
CPU  : Monaco
Board: BD_MST068D_10AHP_14222
HARDWARE ID: 0x21
DRAM:  915 MiB
Now running in RAM - U-Boot at: 58300000
eMMC: HS400 200MHz
eMMC 7.28 GB [E8FFF8h]
Hardware ID for Inception Product: 0x1d21
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
macaddr: 00:9E:C8:7E:FB:AB
MAC:  0x0: 0x9e: 0xc8: 0x7e:0xfb: 0xab
Second power supply is ready. afat
Writing to MMC(0)... 128 blocks written: OK
done
GLED[0x0e38]:48
[CPU INFO] cpu opencreate instance at 57c85528 with private size 44 bytes at 57c85570
[UTOPIA INFO] close moduleNames[38]: MODULE_CPU
cold boot,boot reason:wake_src is 0
msIR_Initialize
AC on
[AT][MBoot][Driver Init][490]
MPOOL size : 0x200000
done
[ERROR] Secure_doAuthentication:94: Error: Authentication Fail!!
jump_to_console start!!
<< MStar >>#
发表于: 2025-8-17 21:30:23
weike88 2025-6-25 17:36
感谢兄弟支招,用了本网的量产软件就可以,想不明白,我自己的量产软件在其它的小米3分体式主板使用过好多次了,都是可以的
本站的量产软件在哪怎么找不到
发表于: 2025-6-22 12:55:51
量产没制作成功,进控制台了
 楼主| 发表于: 2025-6-22 13:24:00
great 2025-6-22 12:55
量产没制作成功,进控制台了
mmc part
Partition Map for MMC device 0  --   Partition Type: EMMC
   #:                 type name                   length   base       (size)
   1:                      MBOOT                    6144 @ 4096       (3.000M)
   2:                      MPOOL                    4096 @ 10240      (2.000M)
   3:                      misc                     1024 @ 14336      (512.000k)
   4:                      recovery                32768 @ 15360      (16.000M)
   5:                      boot                    16384 @ 48128      (8.000M)
   6:                      boot1                   16384 @ 64512      (8.000M)
   7:                      tee                     16384 @ 80896      (8.000M)
   8:                      tee1                    16384 @ 97280      (8.000M)
   9:                      RTPM                      512 @ 113664     (256.000k)
  10:                      system                2097152 @ 114176     (1.000G)
  11:                      system1               2097152 @ 2211328    (1.000G)
  12:                      cache                  131072 @ 4308480    (64.000M)
  13:                      tvservice              307200 @ 4439552    (150.000M)
  14:                      tvservice1             307200 @ 4746752    (150.000M)
  15:                      tvconfig                40960 @ 5053952    (20.000M)
  16:                      tvconfig1               40960 @ 5094912    (20.000M)
  17:                      tvdatabase              16384 @ 5135872    (8.000M)
  18:                      tvcustomer              32768 @ 5152256    (16.000M)
  19:                      tvcustomer1             32768 @ 5185024    (16.000M)
  20:                      persist                 16384 @ 5217792    (8.000M)
  21:                      tvinfo                  16384 @ 5234176    (8.000M)
  22:                      userdata              9437184 @ 5250560    (4.500G)
  23:                      kernelog                 4096 @ 14687744   (2.000M)
发表于: 2025-6-24 09:26:24
回帖奖励 +10 金钱
楼主修好没有?程序能否上传
 楼主| 发表于: 2025-6-24 12:52:33
并没有,试了几个量产,都是一样报错,[ERROR] Secure_doAuthentication:94: Error: Authentication Fail!!
发表于: 2025-6-25 10:14:49
weike88 2025-6-24 12:52
本网站就有量产软件啊,试试呢
发表于: 2025-6-25 16:23:50
有加密,换主芯片后,再用量产软件
 楼主| 发表于: 2025-6-25 17:36:49
高兴平 2025-6-25 10:14
本网站就有量产软件啊,试试呢
GMT+8, 2026-3-19 20:55 , Processed in 0.069835 sec., 12 queries .
