查看: 963|回复: 2
创维酷开K32,亮绿灯打印如下,师傅给分析一下是什么问题?
发表于: 2022-12-15 09:05:55
创维酷开K32,亮绿灯打印如下
COM6, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
J
Hello world!{m3a} svn-r(Apr  2 2015 19:53:30)
init_hwsetting_c
pre_hwsetting_c
post_hwsetting_c
parse hw setting DONE!
internal rom
force emmc
Normal boot
check boot media...
mmc_init...
emmc:read sys info
mmc_read_sysinfo . read sys info@emmc OK
HW: 0x00000ba0
AC: 0x000028e0
UB: 0x0004f678
 ext fw RSA signature verify OK!
emmc:read uboot
GO
U-Boot 2012.07 (Nov 22 2017 -
发表于: 2023-2-18 19:41:56
2023-2-18, 19:31:16 COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
J
init_hwsetting_c
pre_hwsetting_c
post_hwsetting_c
internal rom
force emmc
Normal boot
check boot media...
mmc_init...
emmc:read sys info
HW: 0x00000ba0
AC: 0x000028e0
UB: 0x0004f678
emmc:read uboot
GO
U-Boot 2012.07 (Mar 29 2018 - 11:14:18)
RTC: Init...Running
SCPU: BISR testing ....
SCPU: Finish BISR testing (OK)
CPU  : Cortex-A17
[krsv] use default uboot memory:
bank[0] Start = 0x0, Size = 0x20000000
DRAM:  512 MiB
Watchdog: Enabled
IO Config 2= PIN_PANEL_CURRENT_ADJ@00ffffc800800407
IO Config 2= PIN_WIFI_CONTROL@0000000100014603
IO Config 2= PIN_EEP_WP@0000000100011803
IO Config 2= PIN_BL_ON_OFF@0000000001010804
IO Config 2= PIN_BL_ADJ@00ffffc800800607
IO Config 2= PIN_LVDS_ON_OFF@0000000000010004
IO Config 2= PIN_KEYPAD_PWR@000000143f000701
IO Config 2= PIN_HDMI1_HOTPLUG@0000000001010404
IO Config 2= PIN_HDMI1_DETECT@0000000000001c03
IO Config 2= PIN_HDMI2_DETECT@0000000000001d03
IO Config 2= PIN_HDMI2_HOTPLUG@0000000001010504
IO Config 2= PIN_HDMI3_HOTPLUG@0000000000000000
IO Config 2= PIN_HDMI2_IN_IN@0000000001004703
IO Config 2= PIN_HDMI_MHL_SELECT@0000000100012804
IO Config 2= PIN_LED_ON_OFF@0000000100010204
IO Config 2= PIN_MHL_CABLE_DETECT@0000000000000904
IO Config 2= PIN_AMP_MUTE@0000000001010c04
IO Config 2= PIN_NET_LED@0000000100014403
IO Config 2= PIN_POWER_DETECT@0000000000002504
IO Config 2= PIN_POWER_EN@0000000100010b04
Board: Realtek tv010 Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
To setup mmu...
MMC:   MMC: NOT allocate buffer from non-cache area
emmc:mmc_initial(1) Mar 29 2018 11:14:50
Release SPI Pad !!!
emmc: clk change to 15MHz
mmccr_set_clk: 0x18000204=0x08606001
HW Reset eMMC
reset finish...
RTD294x eMMC: 0
Release SPI Pad !!!
RCA= 0x0
mmc:mmccr_set_bits_width(324) bus width switch to 8bits
emmc: clk change to 50MHz
mmccr_set_clk: 0x18000204=0x08601001
RCA= 0x0
Device: RTD294x eMMC
Manufacturer ID: 11
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 8-bit
Factory: MMC
Factory: seq:0x1e4, blk:0xe000(pp:1), size:0x5800 (to 0xa900000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE,bootparam.prev_power_state=0
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN=0
IMGFILE_PATTERN not found
[bootparam.c 223]:can't IMGFILE_PATTERN
boot_power_on_mode=0
get_layout:
------------tmp/factory/layout.txt found
BOOTPART=0
TAG=21
Factory_RO: MMC
[FAC_RO] No factory_ro data in eMMC
[ENV] read_env from factory failed
[ENV] Using default environment variables
ee read 1396, 1
name=EEP_I2C ppcb_enum.Name=EEP_I2C, ppcb_enum.info=0
EEP_I2C=0
name=PIN_EEP_WP ppcb_enum.Name=PIN_EEP_WP, ppcb_enum.info=100011803
m_PIN_EEP_WP = 0x100011803
I2C power on.69
############Eep_panelID=2##########<<<<<<Panel: sky_SDL320_HY_CD0821>>>>>>>>
panel_init_1st  boot_power_on_mode == POWER_OFF  return
GDMA_ConfigVFlip, linecnt_start = 0x1fff
GDMA_ConfigVFlip, linecnt_end = 0x1fff
GDMA module_init finish
In:    serial
Out:   serial
Err:   serial
Net:   rtl8139: fuse ready = a000001d
rtl8139: link status = 0000ffff
rtl8139: REALTEK RTL8139 @0xb8016800
Hit Esc or Tab key to enter console mode or rescue linux:  0 name=PIN_KEYPAD_PWR ppcb_enum.Name=PIN_KEYPAD_PWR, ppcb_enum.info=143f000701
han_xu index=7,hitvalue=63,torrence=20,lsadc_key1=255
Start Boot Setup ...
         FW Table to 0x0a820000, size=0x00000400 (0x0a820400)
         FW Table fr 0x02000000, fw count: 6
Normal boot fw follow...
Linux Kernel:
         FW Image to 0x00108000, size=0x00fcf208 (0x010d7208)
         FW Image fr 0x02008000 (non-lzma)
Audio FW:
         FW Image to 0x81700000, size=0x001c3180 (0x818c3180)
         FW Image fr 0x02fd7400 (non-lzma)
         Enter standby, skip this entry
Video FW 1:
         FW Image to 0x81a00000, size=0x002eeca0 (0x81ceeca0)
         FW Image fr 0x0319a600 (non-lzma)
Video[image] data 1:
         FW Image to 0x86700000, size=0x0000e376 (0x8670e376)
         FW Image fr 0x03489400 (non-lzma)
(rtkpm_clr_share_mem)2013/04/23 14:55
name=PIN_POWER_EN ppcb_enum.Name=PIN_POWER_EN, ppcb_enum.info=100010b04
(powerMgr_setup_power_en)2012/05/09 15:55
Power enable line have 2 set.
en_power para0=0x100010b04
GET_PIN_TYPE:4
en_power para1=0x0
GET_PIN_TYPE:0
pm_event_msg=0x100000
(powerMgr_setup_irda)2012/05/09 15:55
IrDA Protocol is 0
IR_KEY1=0xcf3f1f1
pm_event_msg=0x110000
(powerMgr_setup_keypad_multi)2012/05/09 15:55
keypad param0=0x143f000701
kptype=1
kpidx=7
PCB_PIN_TYPE_LSADC
KEYPAD_PARM0=0x  173f14
Valid keypad paramteter have 1 set.
pm_event_msg=0x110001
Kernel command line: androidboot.console=ttyS0 console=ttyS0,115200 envp=64100 flashtype=emmc mmcparts=rtkemmc:3866624k,849920k(/system),1048576k(/data),262144k(/cache),16384k(/res),665600k(/skyota),524288k(/media) root=/dev/mmcblk0p1 rootfstype=ext4 ro rootwait earlyprintk ac_on POWERDOWN
Starting kernel ...
Reset ethernet/disable interrupt/flush cache...
bootargs=androidboot.console=ttyS0 console=ttyS0,115200 envp=64100 flashtype=emmc mmcparts=rtkemmc:3866624k,849920k(/system),1048576k(/data),262144k(/cache),16384k(/res),665600k(/skyota),524288k(/media) root=/dev/mmcblk0p1 rootfstype=ext4 ro rootwait earlyprintk ac_on POWERDOWN
boot_jump_linux 0x00108000(0x0,0x138b,0x60100)
bsp_serial_init
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 3.10.0 (www-data@ubuntu) (gcc version 4.8.3 (Realtek ASDK-4.8.3p1 Build 2003) ) #14 PREEMPT Thu Mar 29 11:45:23 CST 2018
[    0.000000] bootconsole [earlycon0] enabled
[    0.000000] cma: CMA: reserved 352 MiB at 02000000
[    0.000000]  System CPU has 1 UART.
[    0.000000]  System CPU uses internal timer interrupt.
[    0.000000]  Ethernet Mac address: 00:10:20:30:40:50
[    0.000000]  Base year of RTC is 2013.
[    0.000000] #@# rtk_init_early(479) release SB2_HD_SEM_NEW_5_reg
[    0.000000] Kernel command line: androidboot.console=ttyS0 console=ttyS0,115200 envp=64100 flashtype=emmc mmcparts=rtkemmc:3866624k,849920k(/system),1048576k(/data),262144k(/cache),16384k(/res),665600k(/skyota),524288k(/media) root=/dev/mmcblk0p1 rootfstype=ext4 ro rootwait earlyprintk ac_on POWERDOWN
[    0.000000] !! switch ir protocol !!
[    0.000000] #@# IR_Init(1507) release SB2_HD_SEM_NEW_5_reg
EMCU ver:?25566
(build: 鍹ay  7 2015 ?1:14:27)
share_reg[0x0]:0x110001
share_reg[0x1]:0x173f14
share_reg[0x2]:0x0
share_reg[0x3]:0x0
share_reg[0x4]:0x0
share_reg[0x5]:0x0
share_reg[0x6]:0x0
share_reg[0x7]:0x0
share_reg[0x8]:0x0
share_reg[0x9]:0x0
share_reg[0xa]:0x0
share_reg[0xb]:0x0
share_reg[0xc]:0x0
share_reg[0xd]:0x5
share_reg[0xe]:0xcf3f1f1
share_reg[0xf]:0x0
share_reg[0x10]:0x0
share_reg[0x11]:0x0
share_reg[0x12]:0x0
share_reg[0x13]:0x0
share_reg[0x14]:0x0
share_reg[0x15]:0x0
share_reg[0x16]:0x0
share_reg[0x17]:0x0
share_reg[0x18]:0x0
share_reg[0x19]:0x0
share_reg[0x1a]:0x0
share_reg[0x1b]:0x0
share_reg[0x1c]:0x0
share_reg[0x1d]:0xb00
share_reg[0x1e]:0x0
share_reg[0x1f]:0x0
0x0 MIN
GMT+8, 2026-3-20 07:22 , Processed in 0.047543 sec., 10 queries .
