Please select To the mobile version | Continue to access the desktop computer version
 Forgot password?
 Register
点此进入购买链接。
View: 443|Reply: 9
新人求助
[Copy link]
Post time: 2019-9-21 11:03:02
| Show all posts |Read mode
接修一台TCL电视型号为HD21M62S高清机,原来问题机器打火,由于看不清原高压包型号在网上查了一下说是BSC25-0215S。买来一个换上后,开机就烧了场供电电阻,场块也烧了,考虑可能是高压包型号不对,肯请大师不吝指教,感谢!
This post contains more resources
You have to Login for download or view attachment(s). No Account? Register
Reply
Use magic Report
Post time: 2019-9-21 11:23:48
| Show all posts
先要检测一共有多少路负载供电,把负载都要断开,检测供电在正常范围内才能挂直负载的!
Reply Support Not support
Use magic Report
 Author| Post time: 2019-9-21 11:34:05
| Show all posts
接修时是正常的,只是打火,原高压包除打火外,看似是正常的呢
Use magic Report
Post time: 2019-9-24 19:53:31
| Show all posts
朱百成万富 2019-9-21 11:34
高压包场输出电压太高了,瞬间烧了场块,考虑是新高压型号不对
Use magic Report
 Author| Post time: 2019-9-25 08:40:13
| Show all posts
不太确切原高压包的型号
Use magic Report
Post time: 2019-9-26 21:35:06
| Show all posts
朱百成万富 2019-9-25 08:40
不太确切原高压包的型号
这个高压包的资料 核对下
Use magic Report
 Author| Post time: 2019-9-26 22:59:35
| Show all posts
感谢关注,可能是购的高压包劣质
Use magic Report
Post time: 2019-10-4 09:45:09
| Show all posts
高压包打火不严重可以处理的不用换
Use magic Report
 Author| Post time: 2019-10-5 22:07:52
| Show all posts
是高压包坏了,购的那个是坏的,打火很厉害的,像放鞭炮
Use magic Report
Points Rules
QQ|Archive|Mobile|iFix 爱修网 ( 京ICP备12043912号 京公网安备11010802011648号 )
2019-10-19 17:23 GMT+8 , Processed in 0.062709 sec., 10 queries .
Release 20180101, © 2001-2019 Comsenz Inc.
MultiLingual version, Rev. 850, © 2009-2019 codersclub.org
